wtf, burning oil again
Old Feb 9, 2004 | 02:05 PM
moondoggy's Avatar
Default wtf, burning oil again
i just got a bunch of stuff done to the car at a garage recently
got the heads milled, all the gasket and valves replaced, etc
the first 2 week i got the car, i regularly checked everything out to see if anything might go wrong....but nothing happened and everything was cool
then 2 week later, all of a sudden my oil level was super low....i was down to like 1/2 litre of oil. i didnt drive the car hard at all since i got it back but i dont see what could have cause it to burn that much oil. there isnt any leaks on the car.
and i can hear this little flapping noise from the engine...althought it's very faint. i think it could be the valve, but i got those replaced thought.....
any suggestions?
btw, this year my car has been a bitch!
Old Feb 9, 2004 | 02:09 PM
moondoggy's Avatar
Default Re: wtf, burning oil again (moondoggy)
oh yeah, forgot to add, i was running with a bad o2 sensor for a few weeks, but just got it replaced
and today on an intersection, the car all of a sudden lost power (then the oil and battery lights came on for a few secs before going away). i waited a few seconds, then i got it going again (no it didnt stall and i didnt restart it)
Old Feb 9, 2004 | 02:56 PM
Jimmy's Avatar
Global Moderator
sounds like you need to pay more attention to your car and dont let oil get low....it could be bad rings?
I thought hondas had 1 head?
Old Feb 9, 2004 | 03:00 PM
moondoggy's Avatar
Default Re: (USDMDC2)
i usually checks under the hood, but 3 litres in 2 week is pretty bad considering i have no leaks
Old Feb 9, 2004 | 03:42 PM
EG2 SiR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by moondoggy &raquo;</TD></TR><TR><TD CLASS="quote">
did you drop an accord V6 in it?
Old Feb 9, 2004 | 03:53 PM
2lua's Avatar
you know where do rebuilt the top end, most of the time the bottom end will need to be rebuilt too. cause right now you top end created a lot of pressure, some thing got to give.
Old Feb 9, 2004 | 04:23 PM
JDMs1eeper's Avatar
Default Re: (moondoggy)
did you replace the valve seals?
if so maybe they were not installed correctly or damaged?
Did it burn oil before?
Could be rings.
My motor doesnt have leaks either and never used to burnt oil, until now. But its because I ran it very rich for a month and wiped the rings out. Maybe running rich with no o2 sensor caused you to burn an access amount of oil. Try an oil change with maybe a 10w40 and keep notice of the oil level. Also when you a flooring it watch your rear view for any signs of burning oil.
thats my .02 But I hope things get better for you. Good Luck
Old Feb 9, 2004 | 04:44 PM
moondoggy's Avatar
Default Re: (Typesi2nv)
yeah, the valve seals were replaced, but i wasnt there to look at it cause i was too busy at work, plus it took him forever to do them.
i'm going to call the dude tomorrow and see if he will look at it again this week......i never burned oil before.....i shouldnt really have burned this much after......i was hoping it's something small
Old Feb 9, 2004 | 04:49 PM
HXvtec's Avatar
is this a y series??
Old Feb 9, 2004 | 04:51 PM
moondoggy's Avatar
z6
Old Feb 9, 2004 | 04:59 PM
Tad's Avatar
Tad
hmm,
seems that my car is doing the same.
d15b7.
i have a flapping noise too,
but i'm pretty sure its my water pump.
dripping coolant from that very area.
was about to change it but I couldnt get my crank pulley bolt off, hehe.
I burn oil too though,
AND I was running super rich for a few months also!
**** hope I didnt crap out my rings...
Old Feb 9, 2004 | 05:01 PM
HXvtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by moondoggy &raquo;</TD></TR><TR><TD CLASS="quote">z6</TD></TR></TABLE>
ok because i know y series love the hide oil. i remember my oil was half a qt low. so i filled it up. next week again half a qt low. so i filled it up. then my car was not used for 2 weeks around christmas time due to my tranny takin a ****. so i checked my oil after those 2 weeks and guess what..... my oil was a full qt OVER. WTF. i think it hides in the cylinder head.
Old Feb 9, 2004 | 05:02 PM
moondoggy's Avatar
my water pump and rad is brand new......so it couldnt be those for me........althought i'm loosing coolant in a very slow pace (like 1/2 L in a couple weeks).....it's not leaking as i've checked
Old Feb 9, 2004 | 05:05 PM
moondoggy's Avatar
Default Re: (HXvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HXvtec &raquo;</TD></TR><TR><TD CLASS="quote">
ok because i know y series love the hide oil. i remember my oil was half a qt low. so i filled it up. next week again half a qt low. so i filled it up. then my car was not used for 2 weeks around christmas time due to my tranny takin a ****. so i checked my oil after those 2 weeks and guess what..... my oil was a full qt OVER. WTF. i think it hides in the cylinder head. </TD></TR></TABLE>
i had that happened to me a few times......but 1/2 qt isnt so bad but 3 litres is just a bit excessive
Old Feb 9, 2004 | 05:09 PM
Tad's Avatar
Tad
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by moondoggy &raquo;</TD></TR><TR><TD CLASS="quote">my water pump and rad is brand new......so it couldnt be those for me........althought i'm loosing coolant in a very slow pace (like 1/2 L in a couple weeks).....it's not leaking as i've checked</TD></TR></TABLE>
maybe your new pump got crapped out somehow?
your coolant loss sounds just like mine,
and it looks as if mine isnt leaking also.
thing is, it only leaks when its running.
so you need to check around the timingbelt right after you turn off the car for any signs of coolant.
Old Feb 9, 2004 | 05:11 PM
G U E C O's Avatar
ya same thing happened to me, i rebuilt my whole engine and the first week i notice that my oil was about 1 quart low, so i fill it up. nextweek low 1 quart again. next next week i its 1 quart low again. next next next week i check and its 1 quart to much. now its been a month and my oil level is good now, no more problems.
Old Feb 9, 2004 | 05:23 PM
moondoggy's Avatar
i guess i gotta keep an eye on everything then.....too bad it's too freaking cold outside to do much, plus my engine bay to so damn dirty
Old Feb 9, 2004 | 06:10 PM
HXvtec's Avatar
i had that happened to me a few times......but 1/2 qt isnt so bad but 3 litres is just a bit excessive </TD></TR></TABLE>
true
GoodUsername
Mar 9, 2015 04:59 AM
Mugen1320
Nov 4, 2005 12:38 AM
T-Mo
Dec 29, 2004 02:59 PM
92HB_HB
Aug 3, 2004 10:04 AM
