b20 in an EG... obd I vs obd II
Old Oct 8, 2001 | 02:12 PM
nsadhal's Avatar
Default b20 in an EG... obd I vs obd II
okay, so all b20's are obd II right?
and EG's are obd I right?
so how difficult is it to hook everything up and make it work, in regards to wiring and vacuum routing?
would this be simpler than converting a pre-obd car (89 crx si) to obd I?
also, is there any difference in the wiring/vacuum setup of b20b and b20z?
i'm looking at putting a b20 straight in, no vtec head or anything.
thanks
Old Oct 9, 2001 | 12:34 AM
Newman's Avatar
New User
Default Re: b20 in an EG... obd I vs obd II (nsadhal)
Use an OBD-1 LS distributor, OBD-1 LS ECU, OBD-1 injectors, OBD-1 alternator, and throw it all in.
Old Oct 9, 2001 | 11:55 AM
nsadhal's Avatar
Default Re: b20 in an EG... obd I vs obd II (Newman)
cool... could i just use the LS manifold too?
Old Oct 9, 2001 | 12:55 PM
B18C-EJ1
Guest
Posts: n/a
Yep, that'd be a real good idea. Or you could get the Skunk2 manifold.
Old Oct 9, 2001 | 01:19 PM
nsadhal's Avatar
Default Re: b20 in an EG... obd I vs obd II (B18C-EJ1)
cool. i remember reading on hybrid.honda-perf.org that some of the fuel maps were a little off or something using the LS ecu and manifold, but i thought that the b20 was just a bored and sleeved b18b?
Old Oct 9, 2001 | 01:20 PM
HX_Guy's Avatar
Yea...bastically use the OBDI LS mnaifold and all the sensor on it...injectors, TB..and the distributor. There's not really many sensors tha tactually plug into the head/block themselves.
Old Oct 23, 2001 | 11:10 AM
cold_blooded's Avatar
New User
"Use an OBD-1 LS distributor, OBD-1 LS ECU, OBD-1 injectors, OBD-1 alternator, and throw it all in."
Any estimates or suggestions on where to get OBD-1 injectors or how much they would cost? I'd hate to see the pricetag on injectors from Honda. But I'm not sure if buying the injectors used is a good thing to do. Can you have a some sort of shop refurbish them or something?
Thanks...
Old Oct 23, 2001 | 10:49 PM
Newman's Avatar
New User
Default Re: b20 in an EG... obd I vs obd II (cold_blooded)
Look online... people sell OBD-1 (92-95) SiR, GSR, or even LS injectors all the time. Or post up asking if anyone has any forsale. As long as they're OBD-1 and from a DOHC motor, that's all you need. Expect to pay anywhere from $40-$80 for a set of used injectors.
JesterDKing
Mar 16, 2013 04:42 PM
lrayford
Apr 3, 2009 08:19 AM
Tbindas
Dec 13, 2005 10:06 AM
zcpowereddx
Nov 7, 2002 04:41 AM
S13 slide
Jan 9, 2002 06:31 PM
