quick question about distrubutor, need quick answer
on a stock greddy turbo kit, or any 'safe' kit, what do you set the distrubutor at?
how much timing do you pull out?
im running uberchip, and i dont have fuel management, so im trying to figure out how much timing does greddy (or anyone) recommend?
thanks in advance...
i set the base timing at 14 ..... from the tune i saw they didnt wanna run anymore than 20 at the top end at 6 - 8 psi .... and for the a/f ratios they ran 11.5 - 12:1 all the way across
u have to find out how much timing the uberchip is taking out. you might just leave it at stock 16. depends on that chip and if it pulls any.
