Boosting on a Carberated engine
Ok, say you wanted to lightly turbo a carb fed engine (this could be a car or a motorcycle engine)
Since you dont have fuel maps and electronics to mess with (unless I am mistaken) the carb will throw more fuel in automatically as boost increases, providing that the flow throuh the carb does not exceed the max fuel flow potential. (please correct me if I am wrong)
I think it would be nice to do a certrifugal set up (belt driven) or possibly turbo depending on the vehicle, and of corse intercool it.
My concern is:what problems will I run into forcing air through a carb (instead of suching air/fuel under n/a conditions)
Another concern would be retarding the timing. would it just have to be set there, or is there a good way to have it retard as boost increases through low tech means.
Also, what do you think of a after carb injector that would kick in when boost was detected to keep from going lean?
thanks to anyone who wishes to join this discusion...
sohc
sohc
Sinner
May 24, 2004 10:44 PM
