Boosting on a Carberated engine
Old Feb 9, 2004 | 12:06 PM
SOHCMAN's Avatar
Default Boosting on a Carberated engine
Ok, say you wanted to lightly turbo a carb fed engine (this could be a car or a motorcycle engine)
Since you dont have fuel maps and electronics to mess with (unless I am mistaken) the carb will throw more fuel in automatically as boost increases, providing that the flow throuh the carb does not exceed the max fuel flow potential. (please correct me if I am wrong)
I think it would be nice to do a certrifugal set up (belt driven) or possibly turbo depending on the vehicle, and of corse intercool it.
My concern is:what problems will I run into forcing air through a carb (instead of suching air/fuel under n/a conditions)
Another concern would be retarding the timing. would it just have to be set there, or is there a good way to have it retard as boost increases through low tech means.
Also, what do you think of a after carb injector that would kick in when boost was detected to keep from going lean?
thanks to anyone who wishes to join this discusion...
sohc
Old Feb 9, 2004 | 12:08 PM
b18bturbo's Avatar
Default Re: Boosting on a Carberated engine (SOHCMAN)
look at getting a blow through carb. The mustang guys use it with great success. just do some reasearch on it.
Old Feb 10, 2004 | 02:33 PM
SOHCMAN's Avatar
Default Re: Boosting on a Carberated engine (b18bturbo)
thanks....
ABK
Engine Management and Tuning
Dec 20, 2008 11:49 AM
CivicWagonRUS
Dec 15, 2006 08:37 PM
nvmyb20hatch
May 24, 2006 04:53 PM
aubry588
Feb 24, 2006 09:46 AM
Sinner
May 24, 2004 10:44 PM
