13's possible? Analyze timeslip, plus a few questions.
My friend took his hatch to the track this weekend for the first time this season. I wanted to get your thoughts on his runs. Do you think he has the power to hit a 13 sec run with more or less no modifications minus the motor?
Next week we're going, thinking of stripping all the interior we can. Taking out the right headlight, un-bolting the exhaust and removing the rear bumper cover.
One, do you think those "free mods" will help? Because we're not into wasting our time.
Two, with the car like it sits, will he see 13's with stickier tires?
Three, What 60's & times can he expect with a 205/50-15 BFG DR?
Timeslip:
Car & Modifications:
* 1995 Honda Civic VX
* JDM B18C (Stock)
* GReddy PE Muffler
* ITR Transmission
* ACT Street Disc Clutch w/Xtreme PP
* VX Wheels w/ 170/70-13 All-Season Radials
A Few pictures:
Thanks H-T
Timeslip:
* JDM B18C (Stock)
* GReddy PE Muffler
* ITR Transmission
A Few pictures:
Thanks H-T
you will run 13's with traction. no problem
with the bf goodrich expect 2.0-2.1 60 foots possibly better with the right suspension setup. anyways strong motor you got.
those free mods will help for sure.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by myhatchrips »</TD></TR><TR><TD CLASS="quote">you will run 13's with traction. no problem
those free mods will help for sure.</TD></TR></TABLE>
Well the suspension won't be changing.
It is,
Suspension:
* KYB Adjustable Shocks
* Neuspeed 2.25" Lowering Springs
* Ingralls Camber Kit
Do you think the free mods will get him into the 13's on the VX wheels & tires?
This is a friends car, not mine.
those free mods will help for sure.</TD></TR></TABLE>Well the suspension won't be changing.
It is,
Suspension:
He can hit 13's on street tires with a better 60' and a little luck (the free mods should help). With the drag radials 13's should be easy.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ActiveAero »</TD></TR><TR><TD CLASS="quote">He can hit 13's on street tires with a better 60' and a little luck (the free mods should help).</TD></TR></TABLE>
I don't think he can pull off a better 60' on those little 13" tires.
Go with what everyone else is sayng, get some drag radials. with the drag radials and removing some weight from the car he should be in the high 13's
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OEMJDM »</TD></TR><TR><TD CLASS="quote">Go with what everyone else is sayng, get some drag radials. with the drag radials and removing some weight from the car he should be in the high 13's</TD></TR></TABLE>
DR's are on order. But with DR's, he doesn't plan on doing any weight reduction.
We only plan on doing the weight reduction and free mods when running the 13" street tires.
I beleive the take off the rear bumper will be good for at least 2 tenths. And then some weight reduction should be good for at least .05 at least. .1 if you take off 100pounds. Did you make the kybs as stiff as possible in the rear? try playing with tire pressure...also try feathering the clutch istead of dumping it.
Should be able to hit 13s even without dragradials
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekhybrd »</TD></TR><TR><TD CLASS="quote">I beleive the take off the rear bumper will be good for at least 2 tenths. And then some weight reduction should be good for at least .05 at least. .1 if you take off 100pounds. Did you make the kybs as stiff as possible in the rear? try playing with tire pressure...also try feathering the clutch istead of dumping it.
Yeah, I plan on taking out the f/r seats, and misc plastic (center console, ect..). I figure i'll shed around 50lbs that way.
They are 4 way adjustable shocks. I set the front on 2, and the rear on 4 (stiffest).
I have not messed w/ tire pressure yet, i usually keep it at its reccomended psi.
As far as the launch goes, I generally launch @ 55-6000 (8000 RL), and feather it through about 3/4 of first gear, then I'll put it down.
Thanks for all the help H-T, keep it coming.
</TD></TR></TABLE>Yeah, I plan on taking out the f/r seats, and misc plastic (center console, ect..). I figure i'll shed around 50lbs that way.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiR831 »</TD></TR><TR><TD CLASS="quote">try some real slicks. </TD></TR></TABLE>
Not interested in running slicks, ever.
DR's or bust.
DR's or bust.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by myhatchrips »</TD></TR><TR><TD CLASS="quote">why? with slicks you get to realize the full potential of your vehicle and how fast it really is.</TD></TR></TABLE>
Because we want the same time at the track that we have on the street.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanAutry »</TD></TR><TR><TD CLASS="quote">
Because we want the same time at the track that we have on the street. </TD></TR></TABLE>
That's what I used to say....until I tried a set of "baby slicks". Then I realized street tires are bullshit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrvx »</TD></TR><TR><TD CLASS="quote">
The BFG's are good for 1.8's . . .
</TD></TR></TABLE>The BFG's are good for 1.8's . . .
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiRkid »</TD></TR><TR><TD CLASS="quote">
have you run your car?
Not at the track.
Not at the track.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chet »</TD></TR><TR><TD CLASS="quote">a friend of mine went 13.7@97 with his b16a.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chet »</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
What was his 60?
Mods?
Just curious.
What was his 60?
Mods?
Just curious.
