Pass smog in Cali with ctr pistions in my ITR
Old Feb 9, 2004 | 08:48 AM
Integ03's Avatar
Default Pass smog in Cali with ctr pistions in my ITR
i have a 2001 integra type R with civic type R pisitons. Compression is about 12.1 and i was wondering if i can pass smog if everything else is stock. Has anyone tried this out before with the new dyno machines? will a thicker head gasket like a cometic 78,000's lower my compression to around 11.5 and if so will that even be enough to pass. I have to go to CHP and get my car smoged there because i got pulled over for no cat. so people let me know what you think
Old Feb 9, 2004 | 09:09 AM
Louie's Avatar
What would Chente do?
Default Re: Pass smog in Cali with ctr pistions in my ITR (Integ03)
ouch..not likely. compression will prolly send nox levels really high
Old Feb 9, 2004 | 03:47 PM
JDMITR222's Avatar
You're fugged with those pistons .
And then you'll most likely be in DMV's little system for high pollution vehicles and your car will likely need to be tested every two years.
So i'd get in good with someone who does smogs especially a Test only station.
Also you have to go to CHP for a smog check?.
Did they catch you with no cat through those little smog checkpoints?.
What i'd do from now on is if you see it up ahead is pull over and let traffic clear so you don't have to drive through all slow.When it clears and it's only you goin through it.Get a little bit of speed and right before you get to it shut your car off and cruise through with the clutch in.As soon as you pass it up cranker up and your off
Old Feb 9, 2004 | 09:39 PM
TurboR1391's Avatar
Man thank god I don't live in Cali. They would impound my car on the spot.
Old Feb 9, 2004 | 09:45 PM
jdmspoonitr's Avatar
Default Re: Pass smog in Cali with ctr pistions in my ITR (TurboR1391)
Yup cops here will pull your *** over and use a mirror on a stick to see if you are running a cat.
Old Feb 9, 2004 | 09:57 PM
Bbasso's Avatar
What kind of tunning device(s) do you have on the car? maybe you could 'fix' it up for the day???
Old Feb 10, 2004 | 09:00 PM
ITR#132's Avatar
Default Re: Pass smog in Cali with ctr pistions in my ITR (JDMITR222)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMITR222 &raquo;</TD></TR><TR><TD CLASS="quote">You're fugged with those pistons .
You already have to test every 2 years in Ca.
Old Feb 11, 2004 | 12:36 AM
Stock@$$GSR's Avatar
Default Re: Pass smog in Cali with ctr pistions in my ITR (Louie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Louie &raquo;</TD></TR><TR><TD CLASS="quote">ouch..not likely. compression will prolly send nox levels really high </TD></TR></TABLE>
What are some ways to reduce nox levels? run 2 cats? use smaller diameter exhaust piping? run really lean? do all of the above? sorry if I sound like a newb, but I would like to know this too, since I'm running CTR pistons in my GSR. Thanks.
Old Feb 11, 2004 | 01:20 AM
d0nkeyxPunch's Avatar
Banned
Default Re: Pass smog in Cali with ctr pistions in my ITR (Stock@$$GSR)
Can't you use a thicker headgasket?
90cb4door
Jun 24, 2010 03:44 PM
JDMguy88
Oct 4, 2008 01:19 AM
TypeRPaul
Mar 20, 2004 02:44 AM
ProudtobeANoob
Mar 7, 2003 02:53 PM
Creamies
Sep 17, 2002 06:38 PM
