99-00 Si stock rim offset
Old Feb 9, 2004 | 07:58 AM
4-banging's Avatar
Default 99-00 Si stock rim offset
anybody have an idea of what this is, 99-00 Si stock rim offset? I want to order some new wheels but I'm not sure what offset to ask for.
thanks in advance...
Old Feb 9, 2004 | 08:55 AM
Andres-eh2's Avatar
4x100, its not rocket science!
Old Feb 9, 2004 | 08:57 AM
Ricey McRicerton's Avatar
Default Re: (Andres-eh2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andres-eh2 &raquo;</TD></TR><TR><TD CLASS="quote">4x100, its not rocket science!</TD></TR></TABLE>
That's bolt pattern rocket scientist! I don't know the stock SI offset. What diameter rim are you going to step up to?? That will help determine what offset you need to buy.
Old Feb 9, 2004 | 09:01 AM
-1TSXer-'s Avatar
Default Re: 99-00 Si stock rim offset (4-banging)
stock offset is 45mm
Old Feb 9, 2004 | 09:05 AM
b16 matt's Avatar
Default Re: (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">
That's bolt pattern rocket scientist! ;. </TD></TR></TABLE>
Own3d
Old Feb 9, 2004 | 09:30 AM
Damon's Avatar
i thought stock is 42mm...can someone verify this?
Old Feb 9, 2004 | 09:58 AM
4-banging's Avatar
Default Re: (Damon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16matt &raquo;</TD></TR><TR><TD CLASS="quote">
Own3d</TD></TR></TABLE>
Andres-eh2 LOSER
That's bolt pattern rocket scientist! I don't know the stock SI offset. What diameter rim are you going to step up to?? That will help determine what offset you need to buy. </TD></TR></TABLE>
I'm going with a set of 17"'s...yea I know I'm probably going to get hounded for this but thats what I want.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -CivicTuner- &raquo;</TD></TR><TR><TD CLASS="quote">stock offset is 45mm </TD></TR></TABLE>
are you 100% sure...thanks
Old Feb 9, 2004 | 10:02 AM
Default Re: (4-banging)
17x what? That's what you really need to know to determine if you are going to rub or not. Hell, you know what it is you want, and if that's 17s, spend your money on them. I damn sure won't knock you for doing what it is you want.
Old Feb 9, 2004 | 10:05 AM
4-banging's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">17x what? That's what you really need to know to determine if you are going to rub or not. Hell, you know what it is you want, and if that's 17s, spend your money on them. I damn sure won't knock you for doing what it is you want. </TD></TR></TABLE>
17x7, oops sorry..
Old Feb 9, 2004 | 10:11 AM
nonsense's Avatar
this isn't rocket surgery people . . . .
Old Mar 3, 2005 | 08:41 PM
c_mack9's Avatar
Default Re: (nonsense)
so is the stock offset 42 or 45? i also need to know. can you be %100 positive please
Old Mar 3, 2005 | 09:05 PM
cursED's Avatar
15x6JJ 45
So the offset is 45mm
Old Mar 3, 2005 | 10:12 PM
imjac1's Avatar
Default Re: (Damon)
what would be the best rim on an 00 si beside stock.
Old Mar 3, 2005 | 11:40 PM
b1ackc1v1c's Avatar
Default Re: (imjac1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by imjac1 &raquo;</TD></TR><TR><TD CLASS="quote">what would be the best rim on an 00 si beside stock.</TD></TR></TABLE> You're kidding right?
Old Mar 4, 2005 | 12:08 AM
Icyrain's Avatar
Default Re: (b1ackc1v1c)
I have a 98 and I'm rocking the si stock alloys. They're awesome. Good combination of size, and looks, versus money. I would stick with them. If you go larger you have to worry about pot holes and ride comfort not to mention if you curb or dent them you'll be shelling out more cash for another one wheras the si's are like $140 which is kinda expensive too but lower compared to some aftermarket. Also if you get a wheel that is larger and looks good it may be pretty heavy and rotation unsprung weight will sap your overall power. Unless you get some SSR Comps which are really lightweight but pretty expensive. You see lots of "tuners" out there with their aftermarket rims but you see a lot less premium OE parts like si alloys. It's up to you really but I would stay with stock.
Old Mar 4, 2005 | 06:51 AM
diabl0451's Avatar
Default Re: (Icyrain)
I have some 17" Racing Hart C6 for sale. $500.00. They were on a silver civic. Looked like the car should have shipped with these rims straight from the factory it was so clean.
Old Mar 4, 2005 | 08:25 AM
strsi's Avatar
Default Re: (diabl0451)
with a 17x7 rim 42 offset is prefered, although most the time u can get away with as little as 40.
Old Mar 4, 2005 | 09:01 AM
Tech's Avatar
Default Re: (strsi)
hatches are ET45 for sure
GONTHAINKHAMISAW
Nov 13, 2006 04:47 AM
o2flow.net
Feb 26, 2006 02:18 PM
RTW DC2R
Apr 6, 2004 03:08 PM
GRAVEDIGGER
Dec 7, 2003 03:55 PM
