Does switching from p/s rack to non p/s rack require alignment?
Old Feb 9, 2004 | 01:44 AM
giff74's Avatar
Default Does switching from p/s rack to non p/s rack require alignment?
I have pulled p/s from my DA, but havent been able to find a non p/s rack to replace what I have. When I do will it require an alignment? I was also wondering if I leave the p/s rack in the car, without any kind of looping, what is the worst that can happen, and how likely is the worst case scenerio?
Thanks
Old Feb 9, 2004 | 07:31 AM
giff74's Avatar
Default Re: Does switching from p/s rack to non p/s rack require alignment? (giff74)
bump
Old Feb 9, 2004 | 07:43 AM
Arsenal's Avatar
When I put a manual rack in my DC2, I needed an alignment becuase the tie rod settings where done on the previous car, so the same will happen for you.
If you convert the PS to Manual you should consider buying the breather kit. Search on H-T and you will see someone who is selling the kits.
Old Feb 9, 2004 | 09:33 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by giff74 &raquo;</TD></TR><TR><TD CLASS="quote">I have pulled p/s from my DA, but havent been able to find a non p/s rack to replace what I have. When I do will it require an alignment? I was also wondering if I leave the p/s rack in the car, without any kind of looping, what is the worst that can happen, and how likely is the worst case scenerio?
Thanks</TD></TR></TABLE>
I don't suggest swapping to a manual rack because manual Civic racks have a slower ratio, which makes it a little easier to turn the wheel, but there are more turns lock-to-lock, i.e. you would have to turn the steering wheel more to steer the front wheels the same amount.
And yes you will need an alignment if the tie-rod ends are ever disconnected.
Old Feb 9, 2004 | 01:34 PM
Arsenal's Avatar
Default Re: Does switching from p/s rack to non p/s rack require alignment? (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">I don't suggest swapping to a manual rack because manual Civic racks have a slower ratio, which makes it a little easier to turn the wheel, but there are more turns lock-to-lock, i.e. you would have to turn the steering wheel more to steer the front wheels the same amount.
And yes you will need an alignment if the tie-rod ends are ever disconnected.</TD></TR></TABLE>
Have you ever driven a Teg with this done? I have an teg with a Civic rack and there is not a great difference. Unless you plan or Auto-x or Tracking alot then it is worth it. On the street it is nice to drive with, also a reassurance that the rack in your car is being used the way it was designed to.
Also the weight savings are great
Old Feb 9, 2004 | 01:44 PM
JDMHN8's Avatar
Default Re: Does switching from p/s rack to non p/s rack require alignment? (Arsenal)
I also don't recommend a manual rack in the DA. Most will say it makes the steering feel better or it's a huge weight reduction, but it's not worth the increased effort or decreased steering precision. I've driven numerous cars with manual racks, and the only difference I can tell is the wheel is harder to turn at low speeds. Doesn't feel different to me at all. If you want to do this, you can only use EF Civic racks.
You might want to try to bypass the variable assist the DA rack has. I imagine if you were able to override the low speed inputs, you would get an even better lock to lock ratio all the time...
DA Integra ALL: 3.7 turns lock to lock
EF Civic HF: 3.9 tuns lock to lock
EF Civic DX/Si: 4.1 turns lock to lock
Old Feb 9, 2004 | 01:47 PM
Community Builder
Default Re: Does switching from p/s rack to non p/s rack require alignment? (JDMDA9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMDA9 &raquo;</TD></TR><TR><TD CLASS="quote">You might want to try to bypass the variable assist the DA rack has. I imagine if you were able to override the low speed inputs, you would get an even better lock to lock ratio all the time...
I didn't understand that part. The ratio remains the same all the time, regardless of the amount of power assist. If you remove the power steering anyway, then the variable assist function is obviously gone also.
Old Feb 9, 2004 | 04:36 PM
giff74's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arsenal &raquo;</TD></TR><TR><TD CLASS="quote">
If you convert the PS to Manual you should consider buying the breather kit. Search on H-T and you will see someone who is selling the kits.</TD></TR></TABLE>
Does anyone know who sells this for the DA? I have talked with Padawan and he doesnt have a working model for the DA.
Old Feb 9, 2004 | 05:06 PM
mugen92acintls's Avatar
Better yet, will some explain how it works so I can build my own?
Old Feb 9, 2004 | 05:13 PM
Default Re: Does switching from p/s rack to non p/s rack require alignment? (mugen92acintls)
So no one on this site knows the functions of a loop-back and breather and how they are modified into the system?
Old Feb 9, 2004 | 07:57 PM
JDMHN8's Avatar
I didn't understand that part. The ratio remains the same all the time, regardless of the amount of power assist. If you remove the power steering anyway, then the variable assist function is obviously gone also.</TD></TR></TABLE>
Me either. I know that the DA is unique because it has a variable assist power rack. At speeds below 30 MPH the wheel is easier to turn than at higher speeds. I myself am not clear on whether this is a result of a variable ratio or magic, but I can really feel the difference. Somehow all this silliness is caused by those 4 lines coming from the "VSS"...
Old Feb 10, 2004 | 02:25 AM
giff74's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugen92acintls &raquo;</TD></TR><TR><TD CLASS="quote">So no one on this site knows the functions of a loop-back and breather and how they are modified into the system?</TD></TR></TABLE>
I have trying to find someone that knows how to do it for this car and not had any luck either.
Old Feb 10, 2004 | 06:14 AM
meltman's Avatar
Ive done it.
1. Take out all power steering equip down to the rack with one barb and one threaded hole.
2. Turn the wheel all the way left and right hard to get about 1/2 the fluid out of the rack. The fluid is only needed for lubrication at this point, not pressure to drive the rack.
3. Get a 1/4" NPT thread barb and put it into the rack next to the barb that is already there with teflon tape on the threads.
4. Now loop the rack back on to itself with some of the left over hoses you removed. One of them is about a perfect fit with a little cutting.
5. Cut the loop in the middle. Get a "T" or "Y" barb fitting and put it in your cut loop.
6. run the other hose up to a breather.
After adding the breather, steering was much easier than with just a belt removed or just the looped rack.
And for some pics and more info, check out this https://honda-tech.com/zerothread?id=184202
I put the "T" in the first picture's loop on the link
*EDIT*
Theres a pic of almost exactly what I did on the second page...
Beejis60
Jul 11, 2010 01:44 PM
Ludehrt
Apr 7, 2009 07:50 AM
NA JDM GSR
May 7, 2006 08:10 AM
Hondacivic90ed
Dec 25, 2005 08:52 AM
yobtah
12
Nov 11, 2003 01:22 PM
