manifold heat?
i finally put my manifold on my car today and i have a question about the heat of it. it will be ceramic coated before the start up but the top of the manifold(like the 180 bend runners) the two runners that are the closest to the valve cover are like .25 inches away from the valve cover. since i will be getting this ceamic coated, do you think it will be ok or should i see if i can fix it? thanks guys
you could fab a heat sheild to help block some of the heat. but it will help only a lil. most of the heat issues should be resloved when the car in motion. a vented hood might help also.
So let me get this straight; your concern is that you will melt the powder coat on your valve cover. Correct? Now that powder coating was designed by honda to stand up the temperatures put off by the head. It's designed to stand up to substantial heat. If the headers are ceramic coated I doubt that they would be able to transfer enough heat to the valve cover to cause the paint to melt. If the header is as high as you say I would be more worried about the hood.
If this is a manifold you bought, did you considered asking the company if they have had any problems with it?
Jake D.
Modified by BlackKnight7 at 5:12 PM 2/9/2004
Jake D.
also, i talked to HPC coatings and the guy up there told me that if you're going to ceramic coat the manifold...DO NOT heat wrap it. thats just what i was told
besides, that ceramic coat helps alot i dont think you'll have problems with the heat messing up the valve cover. what kind of manifold is this? i've never read of anybody having problems like this.
I woulden't touch it after the ceramic coating. I would even run it like that with no coating. Air is a remarkably good insulator and since it should be at least breezy under there I don't think it will matter.
