What all should be changed out when lowering?
Old Oct 8, 2001 | 11:50 AM
ArchAngel Sabastian's Avatar
New User
Default What all should be changed out when lowering?
So far i have thought to change or add the following at one time.
Coilovers
Shocks - Struts
Camber Kit
Rear Lower Sway Bar
Rear Upper Strut Bar
Old Oct 8, 2001 | 03:27 PM
4doorH22's Avatar
Default Re: What all should be changed out when lowering? (Sabastian)
IT's fine to do it one-at-a-time in that order, but if you're having a shop do it you'll save a lot in labor if you get the springs and shocks done at the same time and umm I can't remember if the shock assembly needs to be removed to install a camber correction kit.
Make sure you get an alignment after any suspension work or you may get nasty tire wear.
Old Oct 8, 2001 | 03:48 PM
HoNdAeX11's Avatar
New User
shocks/struts; are they the same thing or are they just two things on one piece?
Specialedition05
Honda Civic (2001 - 2005)
Jul 24, 2006 01:05 PM
.I.Need.Money.
Suspension & Brakes
19
Jun 22, 2006 10:44 AM
hybrid_vtec
55
Oct 21, 2004 08:50 AM
brownman72000
Oct 29, 2002 10:52 PM
hobo79
Jan 22, 2002 06:03 AM
