need help with B series stroker kits.
i went to place my order for a toda stroker kit, but you can't custom order the pistons. i just got back my resleeved benson B18C1 block 84 mm (whoo hoo), and wanted to order pistons with a compression ratio of 9:1 and 84 mm. toda wont do it, and niether will jun. looks as tho im going to have to order an additional set of custom pistons and scrap the toda ones.
any suggestions?
any suggestions?
tried crower yet?
http://www.crower.com/cat/impo...shtml
eagle?
http://www.eaglerod.com/produc....html
its not listed on their site as a kit yet but it was at sema and in a few mags too.
or do a DIY kit, use the B18a/b/B20 crank and rods and whatever pistons you want.
eagle?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snail »</TD></TR><TR><TD CLASS="quote">tried crower yet?
thank you sir! just what i wanted, and $250.00 cheaper
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pete_SI »</TD></TR><TR><TD CLASS="quote">I think JUN and Spoon makes them but they are really expensive</TD></TR></TABLE> im aware they do, i attempted to order the kits, but the only choices you have on the pistons is standard bore @81mm and over bore @ 81.5mm. and both toda, and jun only offer 11:1 compression ratio. since im boosting i need 9:1 or lower.
my resleeved block is 84, also money is not an issue, as i just dropped $900.00 on the resleev job, and $120.00 on the cryo job.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pete_SI »</TD></TR><TR><TD CLASS="quote">I think JUN and Spoon makes them but they are really expensive</TD></TR></TABLE> im aware they do, i attempted to order the kits, but the only choices you have on the pistons is standard bore @81mm and over bore @ 81.5mm. and both toda, and jun only offer 11:1 compression ratio. since im boosting i need 9:1 or lower.my resleeved block is 84, also money is not an issue, as i just dropped $900.00 on the resleev job, and $120.00 on the cryo job.
powerfulperformance
Aug 27, 2001 04:36 AM
