socketed ecu with hondata
Old Feb 8, 2004 | 05:22 PM
TerribleOne's Avatar
Default socketed ecu with hondata
Im buying hondata for the turbo setup Im building, I'll be running the stock gsr manifold so my question is, when I buy a ecu to socket does it matter if its a p28 or p72 when running hondata. p28's are just so much cheaper and easier to find. Or should I just be looking into a straight IM anyway? tia
Old Feb 8, 2004 | 10:56 PM
Default Re: socketed ecu with hondata (TerribleOne)
Old Feb 8, 2004 | 11:24 PM
iH8RICERZ's Avatar
i would contact hondata about that....tell them your plans/set up...and then ask them which ecu you should have socketed..........
Old Feb 9, 2004 | 08:13 AM
Default Re: socketed ecu with hondata (iH8RICERZ)
See now there's a great idea, thanks
Old Feb 9, 2004 | 09:15 AM
streetlvlhatch's Avatar
The p28 wont be able to control the secondary runners on the im. So you will have to take them out in order to use the p28!
Old Feb 9, 2004 | 09:18 AM
Default Re: socketed ecu with hondata (streetlvlhatch)
Is there a way to "gut" the stock IM for straight runners? I mean when I get hondata, run boost and tune it will be a whole different setup then what the stock n/a gsr is working with...hmmm...
Old Feb 9, 2004 | 01:59 PM
you can just remove the runners im pretty sure. Thats what i plan i doing once i install my hondata.
Old Feb 9, 2004 | 02:01 PM
95gsr's Avatar
get a skunk2 manifold
Old Feb 9, 2004 | 03:51 PM
Default Re: socketed ecu with hondata (95gsr)
well the skunk2 is great for my long term goals but right now Im trying to buy turbo setup piece by piece and I might factor that in, but if I can avoid it then I will...
Racing1353
Mar 1, 2009 11:15 AM
aziz93
Aug 16, 2004 08:29 AM
jdm4show
May 22, 2004 11:51 PM
Nextelbuddy
Jul 24, 2003 10:43 AM
StinkyTofu
Dec 29, 2002 11:51 PM
