VTEC Solenoid Problem/Question ***NO PICS***
Old Feb 8, 2004 | 03:36 PM
f@sth@tch89's Avatar
Default VTEC Solenoid Problem/Question ***NO PICS***
I have a 2000 GSR head and the VTEC selnoid i have does not have the vtec pressure switch(green plug). The car is using a 88-91 Si harness w/ a pr3 reprogramed, so its not looking for the pressure switch.
problem: car want rev past 6500 rpm
solution: tried my ECU on friend's car....his car revved to 9k +
Question: What vtec solenoid do i have? and do i need a 88-91 b16a vtec solenoid to solve the problem?
In the mean time i am looking for an obd-0 vtec solenoid
Old Feb 8, 2004 | 04:51 PM
Jared's Avatar
Default Re: VTEC Solenoid Problem/Question ***NO PICS*** (fasthatch89)
vtec solenoids are the same. sounds like a bad ecu
Old Feb 9, 2004 | 07:27 AM
Cm91h22a's Avatar
you just need to get as solonoid that has a pressure switch. I think i have an extra or you can buy a new one from the dealer. You should see if you can barrow one from a friend to make sure that is the problem before you invest in one. I've done swaps where the jdm engine comes with a solonoid that has no pressure switch and has the same problems that your having, as soon as i change the solonoid everything is good
Old Feb 9, 2004 | 09:09 AM
Default Re: (Cm91h22a)
thanx...
scottypippen147
Nov 16, 2010 03:35 PM
TheSickestDC2
Dec 7, 2009 02:29 PM
Dead CIVIC
Jul 13, 2008 01:16 PM
black_99SI
Texas -OK -LA (Sales)
Jul 3, 2007 07:11 PM
