Endless Zeal Type B
Old Feb 8, 2004 | 03:28 PM
Fuel's Avatar
Default Endless Zeal Type B
Just wandering is the zeal coilover good enough for my dc2r??
The spring rate are fr8k and r6k...............n height adj but hv no damper control
Anyone had any experience??
Cheers
Old Feb 8, 2004 | 03:32 PM
BlueR's Avatar
Default Re: Endless Zeal Type B (Fuel)
what is your intended use?
Old Feb 8, 2004 | 03:39 PM
Fuel's Avatar
Default Re: Endless Zeal Type B (BlueR)
70% for street use..............
Cheers
Old Feb 8, 2004 | 03:42 PM
BlueR's Avatar
those will work fine then
Old Feb 8, 2004 | 03:48 PM
Fuel's Avatar
Thanks
Old Feb 8, 2004 | 04:35 PM
ZygSpeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fuel &raquo;</TD></TR><TR><TD CLASS="quote">Just wandering is the zeal coilover good enough for my dc2r??</TD></TR></TABLE>
Define "good enough".
I suppose it will bolt up just fine.
Old Feb 8, 2004 | 04:42 PM
Fuel's Avatar
Default Re: Endless Zeal Type B (zygspeed)
Wat i mean is...comparing the stock setup wth the zeal......It is much more firmer ride,,,as i know the standard setup are very good.......Does anyone wats the standard spring rate for the dc2r??
Cheers
Old Feb 8, 2004 | 08:35 PM
617arg's Avatar
i here good things about the S6 as well
hey look......i see some for sale
https://honda-tech.com/zero...47003
Old Feb 8, 2004 | 09:04 PM
Chris93Si's Avatar
I have Zeal B2's on my car (10k front/6k rear) and they are an improvement over stock. I haven't tracked the car w/ them yet but I did autox a full season w/ them and they worked quite well.
The B's and B2's are a good quality/affordable coilover and definitely an improvment over stock IMHO
Old Feb 9, 2004 | 10:47 AM
Fuel's Avatar
Default Re: Endless Zeal Type B (Chris93Si)
Old Feb 9, 2004 | 11:20 AM
Mike M's Avatar
Founding Member
The B and B2 are pretty much identical, except that with the B2 you can adjust the Dampening (6 Way adjustable) Price difference between the two is not much so I'd suggest going with the B2 and getting some extra adjustability.
Old Feb 9, 2004 | 11:27 AM
.RJ's Avatar
.RJ
Default Re: Endless Zeal Type B (Mike M)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike M &raquo;</TD></TR><TR><TD CLASS="quote">you can adjust the Dampening </TD></TR></TABLE>
Heh...
Old Feb 9, 2004 | 12:41 PM
Fuel's Avatar
Default Re: Endless Zeal Type B (.RJ)
Old Feb 9, 2004 | 05:19 PM
Fuel's Avatar
Old Feb 10, 2004 | 09:51 PM
94integrals's Avatar
I'd go for the B6 or S6... they are an awesome suspension, and the 10k/6k springs are bearable on the street.
Blacklabel182
Suspension & Brakes
Jun 13, 2007 12:17 PM
ricsosan_no5
Apr 28, 2005 07:25 PM
The Destroyer
Suspension & Brakes
16
Mar 23, 2005 11:55 AM
Tad
Apr 23, 2004 10:02 PM
Blazeone
Aug 4, 2003 09:12 AM
