grinding 5th gear?
Old Feb 8, 2004 | 02:36 PM
vtekthis's Avatar
Default grinding 5th gear?
i have 00 b16 tranny with a quaife lsd, and recently its been grinding 5th gear, does the 5 syncro usually go, i think i hit the shift linkage hard like a couple of weeks ago (damm speed bumps), could the culprit be bent shift linkage? is the syncro and service bulliten? any help would be great
Old Feb 8, 2004 | 02:39 PM
sillvercivicgsr's Avatar
Default Re: grinding 5th gear? (vtekthis)
I'd check the shift linkage first then look into the synchos
Old Feb 8, 2004 | 02:43 PM
Built to Spill's Avatar
el diablo
Default Re: grinding 5th gear? (sillvercivicgsr)
it might be the linkage...although linkage is hard to bend, you would of had to hit it pretty hard. how often did you grind 5th before this incident?
Old Feb 8, 2004 | 02:47 PM
vtekthis's Avatar
Default Re: grinding 5th gear? (8grandEG)
never really. there was never a reason to shift hard into 5th, i always took it easy, its just wierd that out of all sycros 5th gear goes? it just amazes me
92civeg
Apr 5, 2010 06:07 AM
B16aCRXSi
20
Nov 7, 2008 11:49 AM
Boostedb20EH2
May 4, 2007 01:51 PM
lacking vtec
May 23, 2006 07:05 PM
snatch
Jul 1, 2004 07:01 PM
