Another weight reduction questions?
Old Feb 8, 2004 | 02:08 PM
RinBlue's Avatar
Default Another weight reduction questions?
Modified by RinBlue at 11:48 AM 8/21/2004
Old Feb 8, 2004 | 02:10 PM
ZygSpeed's Avatar
Default Re: Another weight reduction questions? (RinBlue)
Spare tire and jack?
Old Feb 8, 2004 | 02:11 PM
ZygSpeed's Avatar
Default Re: Another weight reduction questions? (zygspeed)
Rear and passenger seat?
ZygSpeed's Avatar
The stamped pieces that sit under the rear lower seat cushion.
Kendall's Avatar
You can remove all of the SRS system wiring, and the small computer underneath the very center of the dash, I can imagine it would be easier without the dash in as it took me hours to remove the SRS wiring with the dash in.
Old Feb 8, 2004 | 02:12 PM
ZygSpeed's Avatar
Lightweight wheels would make a noticable improvement in weight savings and track performance.
Old Feb 8, 2004 | 02:13 PM
Kendall's Avatar
Bumper supports, power steering, rear wiper, antenna, radio, speakers, speaker brackets, washer fluid nozzles, washer fluid reservoir, the little tab that holds the floor mats in place, the list goes on.
And the dead pedal, take it out too.
Old Feb 8, 2004 | 02:14 PM
ZygSpeed's Avatar
Default Re: (Kendall)
I saw someone on here that took out almost 300 lbs, before welding in the cage.
BTW -- search archived stuff and titles for weight + reduction and get ...
Your search for weight + reduction returned 114 results.
Old Feb 8, 2004 | 02:15 PM
Kendall's Avatar
Lexan windows, carbon fiber body panels, if it's a track car then take out the headlight assemblies and fill them in.
Old Feb 8, 2004 | 02:30 PM
RinBlue's Avatar
I guess i should of been more clear. What i meant is that is there anything else behind the dash to take out. I heard that there
is a bar behind the dash weighing like 10 lbs and its not necessary? I already have the car gutted inside along with the bumper supports,etc.
Cant post anymore due to limit. is there any pics of this bar cause not really sure where it is located.
Modified by RinBlue at 11:41 PM 2/8/2004
Old Feb 8, 2004 | 02:36 PM
Kendall's Avatar
The bar can be removed, but I'm not sure of what kind of effect this will have on safety.
Also, did you remove the body supports in the rear quarter panels? If you don't know what I'm talking about, it's the bolted in piece of metal right behind the ABS computer.
Old Feb 8, 2004 | 02:49 PM
Bbasso's Avatar
Default Re: (RinBlue)
How about FAL I'm sure that would save soime weight.
Old Feb 8, 2004 | 03:02 PM
JeffS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RinBlue &raquo;</TD></TR><TR><TD CLASS="quote">I guess i should of been more clear. What i meant is that is there anything else behind the dash to take out. I heard that there
If you've got the dash off you should be able to see the "bar". There's only one there. It attaches to the sheet-metal mount that the brake pedal and steering column are bolted to and curves down and to the left. I *think* it's just an additional support for the steering column, but it doesn't seem necessary to me. It doesn't weight 10 lbs though.
As stated, take out the SRS computer located underneath the heater core, and take out the SRS sensors located in the firewall at both the driver's and passenger's feet.
There is more information in the archives - even if you can't find it.
Old Feb 8, 2004 | 04:28 PM
AK94GSR's Avatar
Default Re: (JeffS)
Well i have been searching for more things to take outta of my car for weight savings, but ive done most than others.
heres the list of things i have taken out
PS removal
A/C
Rear Bumper Support
Spare Tire and Jack
Rear Wiper
Gsr Wing
Exhaust Heatshields
All Sound deadening tar from under carpet and rear hatch
Misc Bolts and brackets
No Rear Seats or hatch carpet
I weighed in at 2542 w/ me in it and so take away 135
and get 2413
I have since added a CF hood, but havent weighed it since
but my next move is either a fiberglass hatch or cf and some lexan windows for the rear sides and hatch
by the way does anyone know where i could order custom fit windows for the rear of a 3rd gen integra???
Old Feb 8, 2004 | 04:56 PM
Opie's Avatar
Don't let me drive it or in it
Old Feb 8, 2004 | 05:14 PM
davidnyc's Avatar
Were you in Mount Vernon on last Wed. Night, near Gramatan and Lincoln?
Old Feb 9, 2004 | 02:06 PM
RinBlue's Avatar
Default Re: Another weight reduction questions? (davidnyc)
not me car is sleeping right now. is that bar on the pass side also can be removed?
i think i supports the pass side airbag
Old Feb 9, 2004 | 02:08 PM
yoshi234's Avatar
I shoot brides
This may help
Old Feb 9, 2004 | 02:15 PM
b18c1995's Avatar
nope, those wheels are wrapped in and coated in epoxy or clear coat or whatever. The wheels without the CF would weigh less.
missionaryrider
Sep 12, 2005 07:36 PM
leew
Jul 3, 2004 11:55 AM
eRACING
87
Jun 19, 2004 10:38 AM
E-Rok
Feb 17, 2003 11:04 PM
