just installed exhaust, no secondary o2 sensor!
Old Feb 8, 2004 | 12:45 PM
SleepnCiViC's Avatar
Default just installed exhaust, no secondary o2 sensor!
k guys i jus installed my dc jdm header, carsound cat , and apex'i WS II. i decided to leave the secondary o2 out for the time being. i was just wodnering if there will be any ill effects as far as gas mileage, performance etc.... odly though when i had my primary o2 disconnected before it always threw a code, but w/ the secondary o2 gone it does not....
oh yeh the world sport is extremly quiet, and little to quiet in top end.
Old Feb 8, 2004 | 12:53 PM
mstewar's Avatar
Default Re: just installed exhaust, no secondary o2 sensor! (SleepnCiViC)
it doesn't throw a code with the secondary o2 disconnected? that's weird.. it should..
Old Feb 8, 2004 | 12:56 PM
Dr Pooface's Avatar
Default Re: just installed exhaust, no secondary o2 sensor! (mstewar)
It will throw a code eventually. You can ignore it as it does not throw the ecu into limp mode. I know, I drove without one for a year.
Old Feb 8, 2004 | 01:04 PM
mstewar's Avatar
Default Re: just installed exhaust, no secondary o2 sensor! (Dr Pooface)
why not plug it in and just leave it out?
Old Feb 8, 2004 | 04:28 PM
ecu in limp mod.....can you elaborate
Old Feb 8, 2004 | 04:35 PM
B2FiNiTY's Avatar
If you are running the jdm itr ecu, no need for the second o2 sensor.
Old Feb 8, 2004 | 05:12 PM
no usdm
Old Feb 8, 2004 | 05:15 PM
Dr Pooface's Avatar
Default Re: (SleepnCiViC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SleepnCiViC &raquo;</TD></TR><TR><TD CLASS="quote">ecu in limp mod.....can you elaborate</TD></TR></TABLE>
Sometimes, on certian codes the ecu will go into "limp mode". It will think something is wrong and retard timing and lower the rev limit in order to protect the engine.
Old Feb 8, 2004 | 05:17 PM
Dr Pooface's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mstewar &raquo;</TD></TR><TR><TD CLASS="quote">why not plug it in and just leave it out?</TD></TR></TABLE>
Some people have tried that and had no codes thrown.
Old Feb 8, 2004 | 05:24 PM
well it will trigger the check engine light before it goes into limp mod?? so im safe til that comes on correct?
Old Feb 8, 2004 | 05:47 PM
v-attack's Avatar
From: First in Flight, Type Rs of East Coast, NC, FL
In most automotive manufacturer EMS systems the obd2 required secondary o2 sensor is to detect for catalyst deficiency. (If the cat is failing, as in not doing its job.) It might take a while for it to throw a code.
Old Feb 9, 2004 | 05:28 AM
mstewar's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SleepnCiViC &raquo;</TD></TR><TR><TD CLASS="quote">well it will trigger the check engine light before it goes into limp mod?? so im safe til that comes on correct?</TD></TR></TABLE>
CEL for secondary o2 problems do not put the car in limp mode.. so you're fine even when it does come on.. it's just annoying, and could cover up something else that would throw a CEL code..
Old Feb 9, 2004 | 05:31 AM
true, some people told me it wont effect anything! other say i could have bad gas mileage etc....
Old Feb 9, 2004 | 05:34 AM
Dr Pooface's Avatar
Please re-read my post. The absence of the secondary O2 will throw a code and WILL NOT but the ecu into limp mode.
Old Feb 9, 2004 | 05:36 AM
oh ok thanks man, sorry
Old Feb 9, 2004 | 06:11 AM
mstewar's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SleepnCiViC &raquo;</TD></TR><TR><TD CLASS="quote">true, some people told me it wont effect anything! other say i could have bad gas mileage etc....</TD></TR></TABLE>
my gas mileage has been fine without one.. it shouldn't be a big difference even if there was one..
andyvaj
May 2, 2007 06:28 AM
ShittyGSR
Jul 17, 2004 05:59 PM
Shakes
Apr 28, 2004 08:45 PM
chads
Jan 20, 2004 05:07 PM
92Lude
Oct 3, 2002 07:14 PM
