My new Sparco knob is a short shifter.
For a while now I've had this shift **** from a 2003 Accord coupe 6-spd, Its the **** in the little storage place below the e-brake handle. I also have the DC-Sports shoft shift adapter that really shortens the throw front to back. The shifter movement from side to side is not much anyway. I wanted to lower the height of the shifter stalk, I was going to gut the threads off the shift lever and install a new shift **** that uses set screws to hold it in place. I got a new Sparc **** but whe removed the Accord **** I realized the factory **** is only a little over 1.25" deep. And the Sparco **** has a 3" internal shaft...So when I set it in place its perfect...And I didn't need to cut any threads off
Here is the Sparco **** on with the old **** in view.
Here is the Sparco ****, the lower rubber ring is what hides the (3) set screws
Now I need your help, what looks better? The pic above or the one below. I pulled the leather up and around the ****, I used a zip-tie where the large rubber ring was and then pulled it back over the ****...Does it look better?
Thanks guys...
I got the idea from my old 88 1/2 Turbo Supra...You can make a short shifter really easily on those vehicles...
But I totaled it
Modified by GreenBean at 6:12 PM 2/8/2004
Thanks guys...
But I totaled it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Steve26 »</TD></TR><TR><TD CLASS="quote">Do you like the feel of the new ****?</TD></TR></TABLE>
Yes, yes, and yes....It feels better, just keep an old sun-glasses bag or something for those cold mornings...Its like grabbing a ice cube
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by #jefs0ng »</TD></TR><TR><TD CLASS="quote">That's awesome looks beautiful. Too bad I have your older shift ****..</TD></TR></TABLE>
????????????? Wich one?
PatrickGSR94
Apr 4, 2010 09:03 AM
B16Jacques
Sep 20, 2008 09:15 AM
DannyITR
May 28, 2007 09:29 PM
