I've got an exhaust noise ...
As many know by now my present 97 ITR still has the stock exhaust, but I've got this little buzz or rattle at about 3200-3500 rpm when cruising down the road, and as the motor traverses that engine speed.
Figured it was just a heat shield, but look what I found!
The mythical muffler bearing was loose.
I just have to flush and change out the blinker fluid before the the expo!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso »</TD></TR><TR><TD CLASS="quote">HA!</TD></TR></TABLE>
ditto
HA
ditto
HA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zygspeed »</TD></TR><TR><TD CLASS="quote">As many know by now my present 97 ITR still has the stock exhaust, but I've got this little buzz or rattle at about 3200-3500 rpm when cruising down the road, and as the motor traverses that engine speed.
I just have to flush and change out the blinker fluid before the the expo!</TD></TR></TABLE>
Looks like the noise may have been your exhaust finally rusting itself off of the car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BooWeTODD »</TD></TR><TR><TD CLASS="quote">hey ive got the same problem in my gsr, but ive got an apex n1, could my noise be diagnosed with the same problem or do aftermarket exhausts not use that bearing ?</TD></TR></TABLE>
<---slaps himself in the forhead
I can get you the OEM muffler bearings if you need them. They come in sets of two. Retail is $195.99, but I can get you the hook-up discount
What kind of blinker fluid you using?...i heard redline 90-160W was good and allows a steady rythmic blink with no static interference from non static antislitation sources!!!
Wow, looks like you spun a muffler bearing! You know what they say...Lube it, or loose it!
While you're tooling with the exhaust parts, I would recomend bleeding your rear differential just in case...
Hey, just a quick question though...
A friend of mine said I shouldn't use regular Halogen fluid anymore. He said if I use the OS Giken HID fluid that my headlights will flash during v-tech. Is that true?
While you're tooling with the exhaust parts, I would recomend bleeding your rear differential just in case...Hey, just a quick question though...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EVIL_EKology »</TD></TR><TR><TD CLASS="quote">
I believe so.. it blinks faster as the vtak revs up.
I got some JDm fluid if you wanna purchase some, you know how rare it is.
Yeah, I went in for a whole new muffler and they told me I could just use some high-temp lube with a new bearing next time! Imagine that.
I heard the Spoon N1 uses an oversized bearing that fits in some USDM exhausts but not all. I guess you have to check with your local Chief Auto Parts for compatibility
</TD></TR></TABLE>I heard the Spoon N1 uses an oversized bearing that fits in some USDM exhausts but not all. I guess you have to check with your local Chief Auto Parts for compatibility
TTM
18
Oct 2, 2005 04:04 PM
valentinecr
Dec 27, 2004 05:58 PM
