Grounding Question
Old Feb 8, 2004 | 05:48 AM
turboxsi's Avatar
Default Grounding Question
I know all the grounds im suppose to have (-) Battery to frame, tranny to frame (battery in the trunk separate ground), valve cover to frame, and lastly the wiring harness to thermostat housing.
Weird thing is the guy i bought the car from had another ground going from the back of the head (over cylinder #1's intake runner) to the frame of the car. Which also had a little wire spliced into the ground whichs goes to the ITR i/m itself (i guess grounding it, i don't know).
My question is do i really need that last ground i mentioned?? And will the little wire grounding to the i/m do anything (its just screwed in that little hole to the right of the IAT sensor)? Or can i just take out this ground (its like 2 gauge wire)??
Old Feb 8, 2004 | 06:07 AM
B18C2_sedan's Avatar
Default Re: Grounding Question (turboxsi)
try a search. I just read a great post on this.
Old Feb 8, 2004 | 06:11 AM
turboxsi's Avatar
Default Re: Grounding Question (B18C2_sedan)
I have searched quite extensivly to only find what i already know. But i will try and search some more, or maybe you could give me the thread of great information you just spoke of.
Old Feb 8, 2004 | 09:18 AM
https://honda-tech.com/zerothread?id=401216
Also try https://honda-tech.com/zerothread?id=685238
but the first link is better
Coopa B18c5
May 6, 2013 02:09 PM
joelmatt89
Mar 13, 2009 08:45 AM
msinsky14
May 23, 2007 06:44 PM
chile
May 12, 2006 11:51 AM
Wazup
Sep 14, 2005 09:29 PM
