Black ice sucks.
Old Feb 7, 2004 | 10:50 PM
H22SiRaccord's Avatar
Default Black ice sucks.
Ok so i am just driving home and i come to a turn and start to turn. As i turn i start to slid and soon meet a curb. I hit the curb at about 10 maybe 15 but i wasnt sure. I messed up my rim alittle bit. I am hoping that i didnt break any control arms. The steering is all out of wack. I am hoping that it is just the alignment. It drives ok nothing sounds odd or anything. The only problem i found was above 60 it got kinda Shakey.
What are your views on what could be broken? I am just trying to get some ideas before i take it in.
Thanks
Also the steering wheel is not center when i drive.
Modified by H22SiRaccord at 2:12 AM 2/8/2004
Old Feb 8, 2004 | 05:25 AM
Hondaaccordvtec's Avatar
Default Re: Black ice sucks. (H22SiRaccord)
Well, first thing, you're gonna need an aligment - no questions about it.
Second, can you get underneath the car to see any other damage? (Do you have a car jack?)
Possibilities - bent control arm, bent tie rod
Just my 2 cents
Old Feb 8, 2004 | 05:55 AM
jwogen1's Avatar
Default Re: Black ice sucks. (Hondaaccordvtec)
yep you will most definitely need an alignment. if something was broken you would know it, especially if you have had at 60mph since it happened. in the meantime pray its just the alignment and nothing is bent badly
Old Feb 8, 2004 | 06:04 AM
AndyD's Avatar
Default Re: Black ice sucks. (jwogen1)
Ouch, hitting a curb at an angle could mean a lot of things. I don't think you were going fast enough to bend your frame. Hopefully, you were going slow enough to only throw off your alignment.
Old Feb 8, 2004 | 09:05 AM
Stripped Honda's Avatar
99-0104
Default Re: Black ice sucks. (AndyD)
i bet your lca is bent and maybe your knuckle too and if your really unlucky your rear crossmember is bad too
Old Feb 8, 2004 | 01:46 PM
DrunkNRacer's Avatar
Default Re: Black ice sucks. (Stripped Honda)
We have allready established you need an alignment. You will also need to check that rim for bends.. get your wheels balanced while its there for an alignment.
I just spent $90 for an alignment .. damn.. my car rides so smooth now. Remember to ask for a read out from the I.R rack.. <-- this makes sure they lined everything up.
Old Feb 8, 2004 | 04:46 PM
Default Re: Black ice sucks. (DrunkNRacer)
Dam 90 dollars man that is alot. I can get it done for about 60 in oklahoma. Yes it is going in tom. to get fixed. I plan to take the rims off and just put the stock wheels back on for now.
Old Feb 8, 2004 | 05:09 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22SiRaccord &raquo;</TD></TR><TR><TD CLASS="quote">Dam 90 dollars man that is alot. I can get it done for about 60 in oklahoma. Yes it is going in tom. to get fixed. I plan to take the rims off and just put the stock wheels back on for now. </TD></TR></TABLE>
Is your car lowered? because they throw an extra $20 on lowered cars..
Old Feb 8, 2004 | 05:15 PM
Yeah it is........well ****.
Old Feb 9, 2004 | 01:41 PM
Update: Took the car in and no broken parts. I was just in bad alignment...only cost me 39.99 Very happy nothing was really fucked up.
dh1212
Mar 14, 2016 01:17 AM
vtec_crazy
May 30, 2005 10:23 AM
preludacris22
Sep 15, 2004 09:57 AM
Shtryfe
Jul 25, 2003 07:18 AM
