how many miles....
Old Feb 7, 2004 | 10:15 PM
hondaracing1's Avatar
Default how many miles....
how amny miles would you recremend not turboing after....like 70k or somethin
Old Feb 7, 2004 | 10:18 PM
RTE117's Avatar
Default Re: how many miles.... (hondaracing1)
all depends on the condition of the motor. 70K on a Honda motor is still youthful. Do a compression test and make sure your ignition is up to par as well as your fuel system. I'd be 'noid about boosting any motor with over 140-150K but its been done numerous times.
Old Feb 7, 2004 | 10:20 PM
HXvtec's Avatar
what he said^^ how ur car doing?? i know u had some problems with it.
Old Feb 7, 2004 | 10:25 PM
blackeg's Avatar
Default Re: how many miles.... (HXvtec)
im gonna boost on a stock bottom end with 140,xxx miles in a few months. its compression tested between 200 &210, so its healthy and been regularly maintained. if you keep it reasonable with the boost levels it should okay to turbo a higher mileage honda...
Old Feb 7, 2004 | 10:29 PM
SLeePeR012's Avatar
Default Re: how many miles.... (blackeg)
Compression Test can help you find out.
Old Feb 7, 2004 | 10:35 PM
nY's FiNeSt's Avatar
Default Re: how many miles.... (SLeePeR012)
^^^ what they said, as long as your compression numbers are good...boost away. But make sure you tune the car right, that'll be a key part of keeping it from going ka-boom!
Old Feb 7, 2004 | 10:37 PM
my car has 191k i guess thats outta the question...im workin on getting a d16z6 for 400 with shaved head but idk i havent seen the guy online in a while he might of sold it already. and idk i scraped some of that **** out from under the valve cover cuz it was just to bad....and when i go to start it up it has a loud sqealling noise..idk if its a belt or what, but other then that its running pretty good for 191k.
oh and i got a oil leak which is coming from around the oil pan does anyone know what i can do to fix that?
its not going to last to much longer with oil leak and all that dryed up caked up oil all inside of it
Old Feb 7, 2004 | 10:40 PM
RTE117's Avatar
is it the gasket??
Old Feb 7, 2004 | 10:46 PM
Default Re: how many miles.... (IDriveAHonda)
i dont know at first it was just a tiny leak in one spot of the oil pan but now its all the way around it and its around the gasket area but the oil pan looks dented in a little so idk if that may have pusehd it up and messed the gasket up ro what
Old Feb 8, 2004 | 06:37 AM
blackeg's Avatar
its not running down the side or back of your block and just collecting around the gasket is it?
Old Feb 8, 2004 | 07:32 AM
Built to Spill's Avatar
el diablo
i would be hesitant about putting a kit on that motor like you were saying. Def. look into finding a lower mileage z6 or motor of your choice. Abou the oil leak i would look at the oil pan a little better since it is dented...then check the gasket. but it your doin a swap i wouldnt worry about it.
Droolin
Nov 23, 2010 10:56 AM
Y0N1P8T5R1F5A4T
Honda S2000
26
Nov 2, 2009 02:15 AM
Chubz
Honda S2000
Nov 28, 2005 10:23 PM
m0t0rhead
Feb 11, 2004 06:37 AM
Charlie Moua
Dec 30, 2002 07:16 PM
