12:1 comp on 93 pump gas?
Old Feb 7, 2004 | 10:06 PM
HYREV2NR's Avatar
Default 12:1 or higher comp on 93 pump gas?
Is this possible? Are any of you guys running this now? With proper tuning of course. I would think so considering I know a few who run boost on 11:1. Just wondering how high you can go.
Old Feb 7, 2004 | 11:06 PM
Ti3d in's Avatar
Default Re: 12:1 or higher comp on 93 pump gas? (HYREV2NR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HYREV2NR &raquo;</TD></TR><TR><TD CLASS="quote">Is this possible? Are any of you guys running this now? With proper tuning of course. I would think so considering I know a few who run boost on 11:1. Just wondering how high you can go.</TD></TR></TABLE>
12:1 on 93 octane can be done if you have a good tuner.
Old Feb 7, 2004 | 11:28 PM
Casey's Avatar
Default Re: 12:1 or higher comp on 93 pump gas? (Ti3d in)
easily, as long as its tuned well
Old Feb 8, 2004 | 12:16 AM
T.J.'s Avatar
Yeah its possible, no problem actually im running 12:2 on 93 but i am able to get 95 at the pump. Plus its on an untuned motor I am working on getting it tuned but haveing problems with my vtec engaging so cant realy do much.
Old Feb 8, 2004 | 04:20 AM
HYREV2NR's Avatar
Default Re: 12:1 or higher comp on 93 pump gas? (Skunk2whore)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Skunk2whore &raquo;</TD></TR><TR><TD CLASS="quote">Yeah its possible, no problem actually im running 12:2 on 93 but i am able to get 95 at the pump. Plus its on an untuned motor I am working on getting it tuned but haveing problems with my vtec engaging so cant realy do much.</TD></TR></TABLE>Where are U getting 95 @ the pump? Here in Alabama the most I've seen is 93.
Old Feb 8, 2004 | 07:46 AM
meanEG's Avatar
i run 94 on 12.9:1
no prob and i am using ems
Old Feb 8, 2004 | 05:27 PM
T.J.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HYREV2NR &raquo;</TD></TR><TR><TD CLASS="quote">Where are U getting 95 @ the pump? Here in Alabama the most I've seen is 93.</TD></TR></TABLE>
I Live in Greenville SC actually we can get 100 or even 110 at most of the spinx stations here
Old Feb 8, 2004 | 09:20 PM
HYREV2NR's Avatar
I Live in Greenville SC actually we can get 100 or even 110 at most of the spinx stations here</TD></TR></TABLE>And this gas cost how much per gallon?
Old Feb 9, 2004 | 03:57 AM
1 2 NV's Avatar
&lt;&lt;&lt;&lt;12.5:1 on 92. whats tuning???? LOL
Old Feb 9, 2004 | 10:04 AM
lke2drvgsr's Avatar
Default Re: 12:1 or higher comp on 93 pump gas? (1 2 NV)
11.2:1 on 93 never in its life has it been tuned
edit: haha misread the original, thought you were asking 11:1
Old Feb 9, 2004 | 01:14 PM
vtecb20coupe's Avatar
B A N N E D
Default Re: 12:1 or higher comp on 93 pump gas? (lke2drvgsr)
hmmm...i plan on running 12.8:1 on 93 pump gas. with tuning of course.
Old Feb 9, 2004 | 01:31 PM
jeremy.'s Avatar
Default Re: 12:1 or higher comp on 93 pump gas? (vtecb20coupe)
12:1 on 91 with really good tuning possible? plan on going ctr's in gsr block/b16head...i think it yields a bit higher though
Old Feb 9, 2004 | 02:32 PM
Casey's Avatar
Default Re: 12:1 or higher comp on 93 pump gas? (ek_jeremy)
itll be higher. according to sgt who uses ctr pistons on a lot of his motors, itll be 13:1 with ctr pistons in an itr block. FWIW, i ran ctr pistons and a mugen head gasket on my itr motor in my old car, which put it close to 13.4:1 with stock injectors, a fpr and a vafc. I had slight knock at 3.5k to 4k at partial throttle, but with hondata im sure the prob couldve been fixed. 93 octane btw
Old Feb 9, 2004 | 07:18 PM
T.J.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HYREV2NR &raquo;</TD></TR><TR><TD CLASS="quote">And this gas cost how much per gallon?</TD></TR></TABLE>
Well for 95 i pay like 1.55$ a gallon . I never use the 100 or 110 but the 100 is like 2.00$ a gallon and the 110 is i think 3.99 a gallon
Old Feb 9, 2004 | 07:33 PM
jdm_redneck's Avatar
I'm running 12:1 on 94 octane, semi-tuned. lol, no bangs yet
Old Feb 9, 2004 | 07:43 PM
94B18B1Teg's Avatar
Default Re: 12:1 or higher comp on 93 pump gas? (12000rpm)
where the hell are you getting 94 in MD? I live in MD. I ain't seen anything over 94 since Sunoco had some until the chief of fire departments told them they can't carry it anymore because its a safety hazard.
Old Feb 9, 2004 | 08:35 PM
marcin's Avatar
Default Re: 12:1 or higher comp on 93 pump gas? (94B18B1Teg)
12:1 d16z6 here, 93 octane. as of yet still untuned.
curious what kind of engines you guys are running and whats your base timing set at.
im running 12*BTDC
d.
Old Feb 9, 2004 | 08:38 PM
1 2 NV's Avatar
Default Re: 12:1 or higher comp on 93 pump gas? (dvious hatchie)
16 degrees, CR is up above.
Old Feb 9, 2004 | 08:40 PM
biglew's Avatar
How much retard are you all running?
Old Feb 10, 2004 | 06:02 PM
Stunna BEN's Avatar
Don't call it a comeback
Default Re: (biglew)
I would say so. You wont be living with much of a problem. I see people do it all day. Make sure timing is correct, and make sure you run AT LEAST 93 and you are good.
trini-gsr
Sep 27, 2008 03:20 PM
socallmechris
10
Jan 12, 2008 04:42 PM
spooncivic1
12
Nov 24, 2004 07:35 AM
DC2R714
Jul 13, 2004 06:07 PM
B18EG6
May 7, 2003 04:46 PM
