motor mounts
Old Feb 7, 2004 | 10:00 PM
gooknom's Avatar
Default motor mounts
im gettin a civic hatchback with a b16 motor, da car comes with motor mounts, and i dont like da dash shaking, can i get motor mount inserts that make it vibrate less? what can i do please help. any ideas wil help.
Old Feb 9, 2004 | 07:10 AM
saleensolution's Avatar
Default Re: motor mounts (****nom)
what year hatch did you get?
Old Feb 9, 2004 | 08:07 AM
gooknom's Avatar
Default Re: motor mounts (saleensolution)
92 eg
how are u hittin 12's on 3 cylinders?
Old Feb 9, 2004 | 09:21 AM
Farmer Brown's Avatar
If the dash is shaking it's probably case the motor mounts in it are already too stiff.
Old Feb 9, 2004 | 10:02 AM
h22avid's Avatar
Default Re: motor mounts (Djaric)
You could have one of two issues here.
1.) if they are aftermarket poly mounts like the hasport ones then your dash will rattle because they are so stiff. This is very good for performance because there is minimal motor movement thus xfering more power to the ground.... it is a price you pay similar to lowering your car; i.e. it will ride rougher but handle better.
2.) if they are oem stock motor mounts, they are probably worn and inserts wouldn't help much, you would have to replace the mounts.
Now if they are stock oem mounts and they are in good shape then installing inserts will further stiffen the stock mount and would CAUSE not ELIMINATE vibrations due to the stiffness it would create.
Old Feb 10, 2004 | 08:42 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ****nom &raquo;</TD></TR><TR><TD CLASS="quote">92 eg
how are u hittin 12's on 3 cylinders?</TD></TR></TABLE>
ls/vtec on 13psi and dots you gotta love it for full interior and a melted piston
poseghatch
13
May 14, 2013 11:43 AM
GuCBlackEk
Oct 2, 2008 06:06 AM
96SR-V
Mar 17, 2008 04:35 PM
zx2gotboost
Nov 28, 2005 10:33 PM
ID_ten_T
Sep 19, 2004 12:26 PM
