GSR Throttle Cable and LS Throttle cable?????????????
My friend and i just dropped a 98 GSR motor into a 95 LS. Everything so far is going really well. There's only one problem.... When we went to connect the original LS throttle cable to the GSR motor... It's way longer!!!!!!!! Does anyone have remedy for this??? Does anyone have any pointers??????? Hook me up if you can. Thanks
GSRacer
GSRacer
the ls/itr cable is the same lenght... the gsr cable is longer... if you swap a skunk2 manifold on the gsr head, then you can use the ls cable, but other wise, time to get a new cable and bracket...
