what stage clutch!!
Old Feb 7, 2004 | 02:45 PM
SleepnCiViC's Avatar
Default what stage clutch!!
ok guys i wanted start looking into after market clutches for my trans. i was wondering what stage to get. my car currently has i/h/e and future planes consist of hondata tuning and some minor valve train work. i def dont want stage 1, but dont wannat be too over killl so stage 2 or 3????
sorry if im a little to vague in my post.
Old Feb 7, 2004 | 02:50 PM
^jefs0ng's Avatar
Banned
You could stay with stock. My friend had a stage 2 on his LS with almost every bolt on [other than a bolt on FI system] stage 2 or even 3 isn't that bad.. Drive it for 2 weeks and you'll be used to it. I traded cars with him [me having a stock b16] for 2 days and he stalled his car 2 times trying to drive it out of the parking lot.. haha but once you're used to it, you can cruise..
Old Feb 9, 2004 | 04:35 AM
nah i def dont wanne keep stock fly and clutch
Old Feb 9, 2004 | 05:05 AM
JeffS's Avatar
Default Re: what stage clutch!! (SleepnCiViC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SleepnCiViC &raquo;</TD></TR><TR><TD CLASS="quote"> i def dont want stage 1, but dont wannat be too over killl so stage 2 or 3????
Anything over stock is overkill. But hey... if you want to spend twice as much for something that'll wear out in half the time, then go for it.
Old Feb 9, 2004 | 05:17 AM
well im sayin, i want a lightweight fly wheel, so why not beef the clutch up a little while im there.
Old Feb 9, 2004 | 05:18 AM
.RJ's Avatar
.RJ
Default Re: (SleepnCiViC)
A lightweight flywheel does not require a stronger clutch.
Old Feb 9, 2004 | 05:32 AM
ahhhh man, i know that, but the factory clutch wont last forver, so why not just rplace it w/ something while stronger the tranny is down for a new flywheel. and id like to end up w/ 200+whp, so i dont think the factory clutch wille be a good choice down the road
Old Feb 9, 2004 | 05:34 AM
.RJ's Avatar
.RJ
No reason the factory clutch wont last 100K miles.
And if you want to replace it while its apart an Exedy street disc or something while its apart along those lines wouldnt be a bad idea. No reason to get a 4/6 puck unsprung disc for street use.
Old Feb 9, 2004 | 05:40 AM
oh no, def wouldnt get a 4/6 puck disc. yeh i heard alot of good things about exedy, and esp how cheap they are.
Old Feb 9, 2004 | 05:41 AM
.RJ's Avatar
.RJ
I am still confused by what you mean by "stage". If by "stage 1" you mean "stock" then yes thats probably what you need.
Old Feb 9, 2004 | 05:43 AM
sqwerz
Guest
Posts: n/a
Default Re: (.RJ)
well i dont see any reason that you need such a high stage clutch...some stage 1 clutches are good enough to handle way more power than you have..
sometimes those stage2,3,4 clutches just tear up the tranny...but hey its your car.
Old Feb 9, 2004 | 05:48 AM
i was thinkin more on the lines of stage 2, like i had in my 240sx
Old Feb 9, 2004 | 05:51 AM
JBBNJ609's Avatar
why is this in the itr forum and not in the civic forum??
i see nothing ITR about it
edit i see you have a b18c5 in your civic , nvm i guess
Old Feb 9, 2004 | 05:52 AM
ok
Old Feb 9, 2004 | 05:57 AM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SleepnCiViC &raquo;</TD></TR><TR><TD CLASS="quote">i was thinkin more on the lines of stage 2, like </TD></TR></TABLE>
What the hell does this mean? Stage 2?
Old Feb 9, 2004 | 06:08 AM
vtec.dc2's Avatar
Default Re: (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">
What the hell does this mean? Stage 2? </TD></TR></TABLE>
several clutch companies divide their clutch packages into stages.. Stage one would be the mildest and so on. And that usually just means the difference in pressure plate..
Theres no need to replace the clutch unless you're having problems, (rattle/noises/won't hold at certain rpm or engage/disengage). If you get to agressive of a setup, your clutch will last while everything else gets torn apart. I went back to stock disk from unsprung, so i'm running 1800lbs pressure plate and oem bearing with 8.5lbs flywheel. my original clutch was removed after 53K miles and it was in good shape.
Old Feb 9, 2004 | 06:31 AM
Dan GSR's Avatar
Default Re: (.RJ)
its for the dummies that can't understand how a clucth works , and don't know how to buy a clutch
they don't understand, material, pucks, sprung, unsprung, pressure plates
but they can count to as many fingers on their hands
case in point , i know someone with a stock B18B in their civic, he bought a "stage 6" clutch, I told him not to get it, because it doesn't match the rest of the car, well , after about 2 months of use, he detroyed the flywheel, clutch, and transmission
Old Feb 9, 2004 | 06:39 AM
ahhhhhhhhhhh man nevermind guys, thanks for your help. this thread can now be closed moderators
markjokeefe
Oct 4, 2008 12:25 PM
TSX TEX
Mar 19, 2006 09:32 PM
Mgsr
Jun 15, 2005 10:56 AM
JDM EJ1 95
May 16, 2005 07:20 PM
slowsi00
Oct 5, 2003 01:01 PM
