5th gen fuel mileage question
i am trying to monitor my fuel mileage per tank. curious as to approx. how many miles/gallons left when the fuel light comes on. 94 accord which i believe has 16 gallon tank. obviously it will vary due to driving distance/conditions etc., but just wondering if anyone has checked. thanks in advance
5gens have a 17 gallon tank w/ a 2 gallon reserve.....so that means light comes on w/ 3 gallons left...........on CAI and **** spark plugs + ALOT of WOT, im getting roughly 20mpg.......
light comes on with approx 3 gallons left huh. interesting. i am on empty and the light has not come on, so i am curious to see how much longer i can go. thanks man
heres an easier way to do it without knowing you tack capacity, this way is a good estimate of how many miles you get to the tank.
1. Reset your odometer so its on 0 miles
2. Fill the tank up till it clicks and no more
3. Drive around till your next fill up (probably better to drive till close to empty, but you dont need to wait for the fuel light to come on)
4. Fill the tank up till it clicks again
4. Take the miles that shows up on the odometer, divide by the gallons you just filled up, and voila, MILES PER GALLON
this seems to be the easier way for me to figure out my fuel consumption
Well when your car was made they put out ratings for consumers....your gas tank is 17 gallon tank (not sure how big the reserve tank is...but 3 gallons sounds about right). And is rated to get about 25 mpg (city) and 31mpg (highway). Granted this is what the average rating is and is usually higher than what you get. With my 4th gen I get about 27mpg (some highway some city) but the highest I got on the highway was 35 mpg. I would say use your cruise control on the highway whenever possible and avoid braking...let the engine speed slow you down.
yeah, i usually crunch the numbers each tank, but the only reason im trying this is to see if i am losing mileage. during the winter i let her warm up more and what not so i am just checking. i thought my miles per gallon was low--so i am testing the theory. thanks doods
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jwogen1 »</TD></TR><TR><TD CLASS="quote">yeah, i usually crunch the numbers each tank, but the only reason im trying this is to see if i am losing mileage. during the winter i let her warm up more and what not so i am just checking. i thought my miles per gallon was low--so i am testing the theory. thanks doods
with my car the fuel sending unit is f*ed, right now the bars hitting the empty bar but only went 157m. from a full tank... light usually comes on near 300's but i never wait till it gets to that point. i fill up around like 250 to be on the safe side, ny'ers dont stop for one another for help if you get stranded :]
</TD></TR></TABLE>with my car the fuel sending unit is f*ed, right now the bars hitting the empty bar but only went 157m. from a full tank... light usually comes on near 300's but i never wait till it gets to that point. i fill up around like 250 to be on the safe side, ny'ers dont stop for one another for help if you get stranded :]
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jwogen1 »</TD></TR><TR><TD CLASS="quote">yeah i hear ya man--im just testing the waters to see max miles per gallon. im on like 340 and no light yet--we'll see</TD></TR></TABLE>
the last time i seen 340 on mine was 1995 ;[ haha
the most i have gotten out of my 97 manual is 410 miles out of a tank, but on average i usually fill up around 370-380 miles. and my driving is mainly stop and go/around town driving and if i'm on the interstate its only for a like 4-5 miles.
i once drover for 125 miles w/ the needle on empty....50 of those w/ the needle BELOW the line.....i filled b4 light came on too....i ended up having almost 4.5 gallons left....IMO theres gotta be somethign wrogn in design w/ the storage/measurement of fuel systems in hondas....cause that was all fuct up....of ourse mayb all the snow drifting made the gas slosh around too much to get an accurate reading....ah..oh well
FYI on the mileage check--i filled up 5 miles after the fuel light came on. it took 14.75 gallons to fill up. which means there was potentially around 2.25 gallons remaining. I got 360 miles to that tank with a combo of city and highway. which was like 24.5 miles/gallon. not too bad for a 94 with 143k. thats it im out
i put in new set of stock injectors last week and got around 15-16 a gal..
176 miles and filled up 12. something so im guessing a full tanks 250 god damn that sucks...
got ,new plugs + wires + fuel filter + injectors + o2 also... cant figure out what else needs to be done...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fw190bvi »</TD></TR><TR><TD CLASS="quote">perhaps the ecu is looping and running rich???...smell ur exhaust, if it smells like a snowblower, ur runnign rich</TD></TR></TABLE>
how would i fix this? not pretty smart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by James »</TD></TR><TR><TD CLASS="quote">I notice that you live in NYC - maybe 25mpg would be the best you could get if you live in the city?</TD></TR></TABLE>
yea i should be getting alot more, i rarely drive the sucker too...
im not too smart of an ECU guy either....if it DOES smell like a lawnmower (smells like gasoliene is coming out ur muffler), recet ur ECU mayb??? u can alway take it to the dealer and they can run diagnostics on the ECU
yes you should be getting a lot better gas mileage
I am not sure what you can do but-
check tire pressure - low tire pressure uses up 1 to 2 mpg i think.
is your idle speed at 750 rpm (or whatever specified on the manual or under the hood) high idle speed can use up more gas
try fuel cleaner - I use redline fuel system cleaner.
incorrect timing?
operable PVC valve? (new?) Does it make sound when you shake it?
adjust valves? should be done every 15 k miles I think.
carbon buildup from not driving much and done most driving in city - it should not happen but who knows?
binding brakes?
dirty air filter?
timing belts should be replaced every 90 k miles.
thats best I can think of - they are mostly routine maintenance. maybe others can help better.
incorrect timing?
binding brakes?
dirty air filter?
