Lost the wing today. Gained some tunes.
Like the title says, I removed my wing today. Removal was a snap. And I was right, DAMN she looks sexy now. I can't really explain why, maybe cause the back looks shorter, or because the new found plainess of the rear of the car brings out the agresiveness of the front... oh whatever. All that matters is, I like how it looks. Also, rear view visibility is awesome now. No more, "Is that a taxi or a cop...??" The plugs go in on tuesday, and the wing stays safe from thieves in my closet. Until I take her to the track, that is. I also installed my stereo this weekend. What a difference!!!! If any of you like music but still have the stock deck RIP IT OUT!!! Installation of my alpine head unit was pretty easy, I used a universal mounting kit from Crappytire. It was all the wireing for my speakers/deck/amp took so long: eight hours! I'm glad thats over with. Anyways, sorry for ramblin on like that, but I don't know anyone who really gives a **** about cars, and it's nice to know that I can vent here every once in a while. Thanks for reading.
what plugs are you using in peticular, i noticed that the bolt holes arent always so clean, and they sometimes stick out a little, like a crater...
Type R: Four 10m nuts and some double sided foam tape hold the wing on. Remove the nuts and cut the tape with dental floss in a sawing motion. You can't cut it all cause of the bolts, so carefully pull the wing off after you cut all you can. Peel the remaining adhesive off the hatch, wax, and your done.
Slo_Teg: Part # 91601-SR3-000. I have no personal experiance with the plugs as of yet. I get them on tuesday.
Not sure about the part number...
But.. the EG Civic plugs from the shock towers (up front) worked fine on my hatch.
They are located where a factory upper shock tower brace would go if the EG came with one.
Clean the paint off (most likely red
) and install.
Will
) and install.Will
Good Doctor - Any chance you want to get rid of the stock deck? I have some wiring harnesses just laying around, and I'm short a cd player for my truck.
) and install.
Will
) and install.Will
it took u 8 hours to do all that.....it should have been like 45 minutes.....just go to ur local best buy and get a adapter...theyll set u up...its like 10 bucks
Is it alright if the foam adhesive between the spoiler and the body isnt there anymore? I think the body shop that re-painted my hatch failed to put that on.
and again itshuldhave taken 45 minutes to do all that.....hooking up a sytem is no hard.... i just took atthe drivers seat and the back seats whe i dd my system and routed it under the carpet....and did everythign from there....and to get the wire i the door speakers i taped the wire to a clothes hanger
MR Dan
Dec 27, 2005 11:34 AM
mugenracer
Jul 29, 2003 12:11 PM
Drinker
