Timing belt w/ LSvtec
Old Feb 7, 2004 | 02:11 AM
BoOsTiN Dc2's Avatar
Default Timing belt w/ LSvtec
I have a question.... i'm running a ls vtec and i was wondering what i need to run a gsr timing belt... i couldnt really remember but i remember it was something like if i ran a gsr oil pump or water pump then i need to run the gsr timing belt instead of the LS one... anyone know for sure which component i needed to use in order to use the gsr timing belt?? also do anyone know how to tell the difference from a gsr and a LS oil pump?? 94-95 is the year... thanks in advance
Old Feb 7, 2004 | 04:32 AM
b19coupe's Avatar
Default Re: Timing belt w/ LSvtec (tRaCeBuStAbUsTeR)
Which timing belt you run depends on which water pump you have. The oil pump is driven by the crank, and does not affect your timing belt choice.
Old Feb 7, 2004 | 04:45 AM
Default Re: Timing belt w/ LSvtec (b19coupe)
ok that was the answer i was looking for.... thanks
Old Feb 7, 2004 | 04:49 AM
b19coupe's Avatar
NP.
rick_rabies
Apr 1, 2009 12:59 PM
turbob18si
Sep 30, 2008 03:15 AM
B18 CYA
May 11, 2005 03:11 PM
BoOsTiN Dc2
Feb 7, 2004 02:32 AM
infamousALLMTR
Feb 25, 2003 07:17 PM
