built 99 b16a what do u think my #'s will be
Old Feb 6, 2004 | 09:04 PM
NA99CIVICSI's Avatar
Default built 99 b16a what do u think my #'s will be
i recently built an 11:1 comp. 99 si b16, it has 83mm ross pistons, balanced crank, re-sleeved, str block guard, p-n-p head w/ crower stage 2 cams dual valve springs and valves, eagle rods, p-n-p intake manifold, under drive pulleys, dc 4-1 header, apexi n-1 exhaust, msd dist., msd coil, msd sci ignition, msd 8.5mm wires, aem fuel rail and fuel reg.,cometic head gasket,toga racing high volume oil pump, fluidyne radiator, aem cam gears, aem short ram intake do you think it will produce decent power.
Old Feb 6, 2004 | 09:09 PM
infinatenexus's Avatar
Default Re: built 99 b16a what do u think my #'s will be (NA99CIVICSI)
1.Why are you using a block guard on a sleeved motor?
2. What is a "toga racing high volume oil pump".. I assume you meant Toda?
3. I never knew MSD made distributors for B-16's, its not listed on the MSD web site
4. Why are you running a set up like this on a stock OBD2B ECU?
4. You should know exactly how much power it puts down.... unless you never tuned it?
Mike@CCT's Avatar
Formerly Mike@TSR
180 depending on computer system. go with more comp man
Old Feb 6, 2004 | 09:10 PM
Kendall's Avatar
What kind of engine management are you running, and to what extent has it been tuned?
By the way, welcome to Honda-Tech.
Old Feb 6, 2004 | 09:12 PM
Gabe_'s Avatar
Default Re: (Kendall)
1. How come you didn't read the thread stickied to the top of this forum
Old Feb 6, 2004 | 09:13 PM
Kendall's Avatar
We're not trying to be ******** (well not most of us anyway), but your setup makes absolutely no sense whatsoever.
Old Feb 6, 2004 | 09:17 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">We're not trying to be ******** (well not most of us anyway), but your setup makes absolutely no sense whatsoever.</TD></TR></TABLE>
Thats what I was thinking.... I wouldn't have looked over it more than once... until I noticed a STR block guard, then the term re-sleeved. Then I looked at it a little closer....
i dont yous are ******** i am writing this to get advice. things i should change and what not
Old Feb 6, 2004 | 09:18 PM
Default Re: (NA99CIVICSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NA99CIVICSI &raquo;</TD></TR><TR><TD CLASS="quote">i dont yous are ******** i am writing this to get advice. things i should change and what not</TD></TR></TABLE>
"Things I should change"...... your first post started off with "i recently built"
Old Feb 6, 2004 | 09:19 PM
it does not have solid sleeves in it that is why i chose to run the block guard
Old Feb 6, 2004 | 09:20 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NA99CIVICSI &raquo;</TD></TR><TR><TD CLASS="quote">it does not have solid sleeves in it that is why i chose to run the block guard</TD></TR></TABLE>
I hate to tell you.. but if you run after market sleeves... a block guard is 100% worthless. Even if you have stock sleeves.. you don't need it on your set up.
Old Feb 6, 2004 | 09:24 PM
Default Re: (infinatenexus)
reason im on here is to learn more. where i am from in pa no one seems to know or wants to work on hondas thats y i came here to get advice and up here that is the setup advice i got
Old Feb 6, 2004 | 09:29 PM
Kendall's Avatar
Then let us give you advise.
First piece of advise: remove the block guard, at this point it does nothing but restrict coolant flow.
Second piece of advise: acquire some good engine management and PLEASE have it tuned.
Old Feb 6, 2004 | 09:33 PM
i thank you for your advise this is y i came here
Old Feb 6, 2004 | 09:35 PM
Kendall's Avatar
Also, are you running the DC JDM header, or just the standard DC?
victor.ek4
189
Dec 4, 2009 02:36 PM
XKINGX
Jun 20, 2009 12:23 PM
MVCIVIC
Mar 11, 2008 07:38 PM
playAho
Mar 25, 2003 10:05 PM
OneThirtyEight
Nov 19, 2001 06:05 PM
