TurboEdit Questions...
Old Feb 6, 2004 | 08:35 PM
Bleed Black's Avatar
Default TurboEdit Questions...
I just dont really know HOW exactly you burn the map/timing/vtec/etc changes from your PC to the chip on the ECU. Im in research phase and trying to wiegh my options for everything.
88 CRX DX. Set up will most likely be Turbo D16z6. Maybe just high compression via D16a1 pistons but still VERY undecided. Building it from the ground up so adding power is one of the later steps. Im still trying to decide on wiring/ECU options. Whether to go P28 with one of Blown90Hatch's harnesses or stick with OBD0 with a reprogrammed PM7/PG6. Input will be greatly appreciated. But Ill have more post regarding my build-up as I approach certain aspects of it.
Old Feb 7, 2004 | 12:59 AM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default Re: TurboEdit Questions... (slowasshatch)
http://www.pgmfi.org
check my sig as well
Stan
mintonbt529
Jun 16, 2011 06:11 AM
cor4ey
Mar 16, 2008 08:58 AM
chris61988kb
13
Jan 19, 2007 10:28 AM
Tyreece04
10
Jun 17, 2004 02:19 PM
DX Hybridizer
May 7, 2003 04:26 PM
