bouncy!!
Old Oct 7, 2001 | 07:41 PM
Kazmans94cord's Avatar
Default bouncy!!
i know a lot of yall have lowered accords...i dunno bout yalls but mine tends to be kinda jumpy over the littlest bumps..is there anything to reduce that? like a tie bar or sway bar?
Conechaser's Avatar
Default Re: bouncy!! (kazmans94cord)
how much did you lower your car? stock shocks?
Old Oct 7, 2001 | 07:44 PM
Default Re: bouncy!! (94Accord)
i have ground control coilovers...so right now im 2 inches lower in the front and 1.5 in the back...prob 2 inches now with my system..and yes stock shocks..part of the problem?
Old Oct 7, 2001 | 07:45 PM
Conechaser's Avatar
yeah, its your shocks. Stock shocks can't handle lowering that well.
Old Oct 7, 2001 | 07:46 PM
what kind would you recommend?
Old Oct 7, 2001 | 07:48 PM
Conechaser's Avatar
i have KYB AGXs and i love them, but for daily driving, any aftermarket brand will be ok. Tokico are prob the cheapest w/ KONIs being the most expensive.
Old Oct 7, 2001 | 07:49 PM
yeah i heard tokico were the best for the price...would anything else help me?
Old Oct 7, 2001 | 07:52 PM
Conechaser's Avatar
not really. hrm, Do you know what your spring rates are?
Old Oct 7, 2001 | 07:55 PM
umm...no clue...where can i find that out?
Old Oct 7, 2001 | 07:59 PM
Conechaser's Avatar
i think it says on the springs from GC, im not sure w/ their setup.
Old Oct 7, 2001 | 08:01 PM
ok ill have to check it out....tomm def...way way to dark...
Old Oct 7, 2001 | 09:11 PM
smokin rubber's Avatar
I installed my kit a couple of weeks ago and the springs had #s on them but not pound rates.
Old Oct 7, 2001 | 09:43 PM
John's Avatar
New User
Default Re: bouncy!! (smokin rubber)
it's the spring rates... my Skunkworks coilovers have a high rebound rate, which is especially noticable in the rear... the way i look at it is this... try and push down on your car... notice that your suspension has no compression... so when it goes over an imperfection in the road, it follows the exact contour of that dip or bump... and that is passed on to the driver...
Old Oct 8, 2001 | 06:38 AM
Default Re: bouncy!! (DunReit)
exactly..whenever i go over a bump its like the rear end off the car jumps up..is there anything to correct it??
Old Oct 8, 2001 | 06:40 AM
SOHCArchangel's Avatar
yea, you need to find shocks that will dampen the spring rate of your springs sufficiently, i will be going to bilstein hd's next..
Old Oct 8, 2001 | 06:42 AM
Default Re: bouncy!! (SOHCkordVTEC)
i guess thats what i gotta do then.....
Old Oct 8, 2001 | 07:39 AM
John's Avatar
New User
I use Koni adjustables... would a softer shock help with the rebounding effect, or would my handling be compromised by going with another shock? After all, my shocks are four years old... but I don't want to have to sink the money in a new set of shocks if I don't have to (so I can put the money into other aspects of the car ).
Old Oct 8, 2001 | 08:22 AM
urbanlegend21's Avatar
New User
get your shocks rebuilt
Old Oct 8, 2001 | 11:38 AM
John's Avatar
New User
Default Re: bouncy!! (urbanlegend21)
How much does rebuilding shocks cost, and what exactly is involved in the rebuilding process of the shocks?
Old Oct 8, 2001 | 11:41 AM
so i guess what it all adds up it is i need to buy new shocks??
homemadeturbo
Suspension & Brakes
11
Jan 25, 2008 07:49 PM
sohcSUCKS
Suspension & Brakes
Feb 16, 2005 06:45 PM
dip-set
Feb 10, 2003 05:18 AM
SOHC_MShue
Feb 6, 2003 05:12 PM
garados
Feb 17, 2002 02:57 PM
