Help...No tailights or corner lights
Old Feb 6, 2004 | 07:47 PM
KayOs's Avatar
Default Help...No tailights or corner lights
We have gotten a tremendous amount of rain here today on the east coast. My tailights and corner lights are not lighting up when turned on.
They turn on when I depress the brake pedal only. When I let go of the brake pedal they shut off again. I checked and replaced the fuse.
I am clueless here. Feedback is appreciated.
Old Feb 6, 2004 | 08:01 PM
Discosteak's Avatar
Default Re: Help...No tailights or corner lights (KayOs)
start punching things, thats how i got mine to come back on , then when it did it again i stopped being so lazy and found out that i had a loose connection under the dash
Old Feb 6, 2004 | 08:02 PM
Hondizzle!'s Avatar
Default Re: Help...No tailights or corner lights (BADEG6)
this topic was on here about two days ago, guy had almost exactly the same problem, try a search
Old Feb 6, 2004 | 08:03 PM
KayOs's Avatar
What exactly was loose under your dash?
Thanks.
Old Feb 6, 2004 | 09:39 PM
KayOs's Avatar
ttt, any ideas?
Old Feb 6, 2004 | 09:41 PM
DumpedSi's Avatar
Default Re: (KayOs)
check fuses.. Unlikely.. but the best place to start when trouble shooting
Old Feb 7, 2004 | 04:01 AM
TABIAS's Avatar
I want to be MADE into Ice-T
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KayOs &raquo;</TD></TR><TR><TD CLASS="quote">We have gotten a tremendous amount of rain here today on the east coast.</TD></TR></TABLE> yeah i know right, i was driving and my car cut off.... so i went home and took of my cai to put on a short ram, and i dumped water out of my filter... grrr i hate lots of rain... umm i'd check fuses, then look for any loose conections good luck man
Old Feb 7, 2004 | 09:57 PM
KayOs's Avatar
Circuit tested every damn fuse under the dash and under the hood.
Could the foglights and its wiring harness be the issue? Someone mentioned a faulty brake switch...you guys ever diagnose a faulty brake switch under the dash connected to brake pedal?
Old Feb 8, 2004 | 01:29 PM
KayOs's Avatar
Combination light switch is what I am suspecting.......The #19 fuse under the dash has power to only one side of the fuse. Indicators do not light up steady when turned on but they do indicate when the appropriate turn signal is selected. When I press on the brakes with the parking lights to the on position, the taillights go on and so do the front parking lights. When I release the brake pedal with the parking lights still on, the front corners go off with the letting go off the brake pedal.
Old Feb 8, 2004 | 08:03 PM
KayOs's Avatar
Looking for the real deal electrical gurus of honda's...cmon guys....
Old Apr 11, 2004 | 09:58 PM
H22A EG6's Avatar
Default Re: (KayOs)
same prob need help
Old Apr 12, 2004 | 10:05 PM
KayOs's Avatar
Check all your bulbs. I had a rear taillight bulb that its base has completely melted down. This was causing a short throughout the car and preventing my lights from responding accordingly.
Old Apr 13, 2004 | 02:29 AM
DiRT!'s Avatar
sounds like a fuse
ShawnS4363
Sep 2, 2008 01:23 AM
B18Sleeper
38
Jan 29, 2007 09:24 PM
KaoticSnow
Jan 25, 2007 09:52 AM
YouGotHacked
Honda Civic (2001 - 2005)
Nov 16, 2006 09:52 PM
