axle fitment
Old Feb 6, 2004 | 07:05 PM
partsguyonline's Avatar
Default axle fitment
What axles?????
91 Crx Dx with Si front spindles:
HAsport billet mounts, b16 half shaft, & b18c engine & y1 trans.
When driving I hit a dip and its seems like its bottoming out, but its the axles!!!
Modified by partsguyonline at 5:49 AM 2/7/2004
Old Feb 6, 2004 | 07:11 PM
Redline130's Avatar
Default Re: axle fitment (partsguyonline)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by partsguyonline &raquo;</TD></TR><TR><TD CLASS="quote">What axles?????
HAsport billet mounts, b16 half shaft, & b18c engine & y1 engine.
When driving I hit a dip and its seems like its bottoming out, but its the axles!!!</TD></TR></TABLE>
I assuming you meant Y1 tranny. If you are using the Y1 half-shaft as well, you will need to use SiR axles. Otherwise, switch to a 90-93 Integra half-shaft and use 90-93 axles.
Old Feb 6, 2004 | 07:40 PM
Cory man's Avatar
If you have a y1 intermediate shaft you need a driver side axle from a 88-89 teg and a pass axle from a 90-91 teg. Even this axle combo isnt the greatest as the driver side axle is still a bit short if I recall(something like that). Easiest thing to do is get an intermediate shaft from a 90-93 teg and use the same yr teg axles. HTH
Old Feb 7, 2004 | 10:53 AM
Default Re: axle fitment (Cory man)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cory man &raquo;</TD></TR><TR><TD CLASS="quote">If you have a y1 intermediate shaft you need a driver side axle from a 88-89 teg and a pass axle from a 90-91 teg. Even this axle combo isnt the greatest as the driver side axle is still a bit short if I recall(something like that). Easiest thing to do is get an intermediate shaft from a 90-93 teg and use the same yr teg axles. HTH</TD></TR></TABLE>
both side 93 axle or just the right side?
EF-ingB16
Jan 8, 2011 04:22 PM
tsbabygurl1986
Oct 10, 2008 09:13 PM
thatbluecrx
Oct 11, 2004 02:11 AM
Kasper.
Jan 31, 2004 12:28 AM
mobrep
Aug 29, 2002 03:06 PM
