1st generation integra..b series swap questions
Old Feb 6, 2004 | 06:18 PM
illicon2003
Guest
Posts: n/a
Default 1st generation integra..b series swap questions
I was wondering if anyone here has or knew someone with a 1st generation (with the pop up lights) integra with a b series motor swap. I read about it online a bunch and I saw that it require a whole bunch of stuff from Hasport. Axles, mounts, wire harness, etc. I'm just curious because the chassis is only around 100 or 200 pounds heavier than an EG. I think they look cool and was thinking about doing something original. I appreciate any comments/info. Thanks
Old Feb 6, 2004 | 07:32 PM
KaBlammyman's Avatar
Default Re: 1st generation integra..b series swap questions (illicon2003)
The swap is almost a bolt in thanx to the good people at Hasport. You will need the engine mounts, ecu, wiring harness, tranny, axles and some other odds and ends. Hasport provides the enigne mounts and wiring harness and stuff like that. The engine fits the g1teg well, but is kinda expensive (it is for g1teg owners). You can goto http://www.g1teg.org and talk to a few of the members how have the swap done. Ther are a few with b16s and 1 with b18c5 swap.
jason_srdet
May 13, 2010 12:19 PM
**DOHC HaTcH**
Feb 16, 2007 03:53 PM
fbpem1
Apr 28, 2006 03:03 PM
dgrave
Dec 14, 2004 07:05 AM
