what kind are these cams?
Old Feb 6, 2004 | 04:03 PM
91lsvtecrx's Avatar
Default what kind are these cams?
what are the differents between the gsr cams and itr cams and how can i tell the differents? thanks
Old Feb 6, 2004 | 04:16 PM
ATS*Mark's Avatar
OG triple OG
Default Re: what kind are these cams? (91lsvtecrx)
one will look different than the other.....
naw fo reals tho , i forgot how to cosmetically tell the difference.
performance wise the itr's are much better NA performance than the gsr cams.
Old Feb 6, 2004 | 04:41 PM
LudeHatchH22a's Avatar
Default Re: what kind are these cams? (Hella_JDM)
"one will look different than the other.....
performance wise the itr's are much better NA performance than the gsr cams."
lol, right
the only real way for you to find out is invest in a micrometer and get the specs of the cams, then measure, you should be able to at least tell which one is bigger.
Old Feb 6, 2004 | 05:32 PM
RedlinedVTEC's Avatar
Default Re: what kind are these cams? (LudeHatchH22a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeHatchH22a &raquo;</TD></TR><TR><TD CLASS="quote">
Are you kidding me? All OE B-series cams have marks to distinguish them from one another. http://www.ff-squad.com/tech/cams/ Katman has a nice collection of pictures and descriptions to help differentiate OE B-Series cams.
Old Feb 6, 2004 | 06:09 PM
91lsvtecrx's Avatar
Default Re: what kind are these cams? (RedlinedVTEC)
thank you RedlinedVTEC for answering my ?
MikeNice's Avatar
The lobes on the ITR would be bigger then the GSR. Look for the motor code or maybe the ECU code. If that fails, it should have a part number, call Honda and ask what the number means.
Old Feb 6, 2004 | 06:17 PM
TwistedSI's Avatar
Mine look like this.....
j/k Generally you want to look for the rings. 2001+ ITR and CTR cams have 2 rings on the distributor side of the intake cam.
JPerkMr954
Apr 5, 2011 07:13 AM
B16b-EJ8
Jul 20, 2007 02:12 PM
blkgsr03
Aug 3, 2004 05:12 AM
Red Rocket
Mar 24, 2004 01:01 PM
