Pressure plate????
Old Feb 6, 2004 | 03:21 PM
HondaRacer32's Avatar
Default Pressure plate????
Wat does a pressure plate mean and wat is its role wit the clutch, cause when i searched nuttin came up.. and also does clutchmasters make a clutch for a GSR motor because the highest motor is only 1.7L, thanks!!!
Old Feb 6, 2004 | 05:38 PM
b19coupe's Avatar
Default Re: Pressure plate???? (HondaRacer32)
The pressure plate is what engages and disengages the clutch disc. The clutch disc is connected to the input shaft of the transmission via its splined hub. When you step on the clutch pedal, the springs of the pressure plate are released, allowing the clutch disc to spin independently of the flywheel. Take your foot off the clutch pedal and the springs of the pressure plate clamp the clutch disc to the flywheel, effectively locking the input shaft of the transmission to the engine. The input shaft is then spinning at the same rate as the engine.
Old Mar 5, 2004 | 02:00 PM
iam7head's Avatar
Default Re: Pressure plate???? (b19coupe)
pressure plate is aonther name for clutch cover, there's two type, honda uses the diafram(sp) type aka multi-finger instead of Spring.
AWD: Jeff
Transmission & Drivetrain
Jun 2, 2010 08:04 AM
crowder13
Jan 14, 2008 01:56 PM
SuicideSlide
11
Aug 29, 2004 01:25 PM
John
Nov 29, 2001 07:29 PM
