tightening throttle cable?
Old Oct 7, 2001 | 06:38 PM
Ibuprofen's Avatar
Default tightening throttle cable?
too much slack i think..how do u tighten?
Old Oct 7, 2001 | 06:55 PM
Wildohiorice's Avatar
New User
Default Re: tightening throttle cable? (ITyp3R)
2 nuts between a bar. loosen the 1 towards the throttle body. tighten the cable to where there is minimal slack in the line make the cable almost taught but so where it doesn;t more the throttle rotor. then retighten the nut back down. need 1 10mm wrench i believe. once u look at it and loosen the nut u will see how it operates its pretty simple. first mod i did.
Old Oct 7, 2001 | 08:09 PM
travis's Avatar
Default Re: tightening throttle cable? (Wildohiorice)
Deflection spec is 10-12mm. You can actually get it less than that, but anything too tight and your idle will be too high.
Old Oct 7, 2001 | 08:11 PM
Ibuprofen's Avatar
Thanks! that was easy!
Old Oct 7, 2001 | 08:34 PM
Xerzex's Avatar
New User
I might do the same thing when I get a chance. Thanks!
delguiner
Jun 15, 2004 12:08 PM
sslude
Aug 29, 2003 04:53 PM
blunty
Apr 22, 2002 07:51 AM
integra99blue
Jul 16, 2001 07:56 PM
