broke my tps on my 2k si throttle body would an ls one fit?
Old Feb 6, 2004 | 01:11 PM
Turbo D' Sol's Avatar
Default broke my tps on my 2k si throttle body would an ls one fit?
i broke my tps on my throttlwe body puittin my motor in a truck because it was suspose to go in my car today but nope i need to find a throttle body for it now what throttle bodys yould fit my 2000 civic si?
Old Feb 6, 2004 | 02:35 PM
TeamNextGenChris's Avatar
Default Re: broke my tps on my 2k si throttle body would an ls one fit? (Turbo D' Sol)
you can change the TPS-no need to replace the throttle body.you can use one off any sidedraft honda.the only ones you can't use are the downdraft style(cars with the TB facing upward)-they rotate the wrong way(from DPFI EFs,and i beleive the EK downdraft cars also turn the wrong way).
chris
Old Feb 6, 2004 | 02:41 PM
b20vtec ef8's Avatar
I would go a typical Tape R manifold but that is just me
Old Feb 6, 2004 | 02:42 PM
Default Re: broke my tps on my 2k si throttle body would an ls one fit? (b20vtec ef8)
Type R*
Old Feb 6, 2004 | 03:38 PM
boostsohfast's Avatar
Isn't the tps like wound up inside and thats why Honda doesn't put normal bolts on them so you can remove them? I remember switching a couple TPS sensors and after that there were some idling problems.
Old Feb 6, 2004 | 03:54 PM
Default Re: broke my tps on my 2k si throttle body would an ls one fit? (boostsohfast)
the TPS is a simple potentiometer.it has a keyway that locks into the throttle plate. you just have to adjust it once it's installed.
chris
Old Feb 6, 2004 | 03:55 PM
mattssi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20vtec ef8 &raquo;</TD></TR><TR><TD CLASS="quote">I would go a typical Tape R manifold but that is just me</TD></TR></TABLE>
How does this relate to his question? Not at all! Don't replace the TB, just get a new tps!
Old Feb 6, 2004 | 04:00 PM
Default Re: broke my tps on my 2k si throttle body would an ls one fit? (TeamNextGenChris)
thanks chris
turboef90
Mar 23, 2009 10:07 AM
dohc_profile
Feb 24, 2007 09:08 AM
bustdgst
Dec 29, 2005 06:55 PM
ek_99_SiR
Jul 19, 2005 09:34 PM
eldorko86
Jul 17, 2005 07:19 PM
