civic revving noises
Old Feb 6, 2004 | 12:15 PM
nice94eg6's Avatar
Default civic revving noises
Well lately my car has been revving like on and off...Im just trying to figure if there is something wrong. It sounds like Im tapping the gas pedal over and over and I dont know whats up with that when Im just sitting at idle. Let me kow
Old Feb 6, 2004 | 12:18 PM
=GAME='s Avatar
Default Re: civic revving noises (nice94eg6)
vaccum leak? iacv? any codes?
Old Feb 6, 2004 | 12:20 PM
kKdARIAN's Avatar
Vice President/CEO
Default Re: civic revving noises (=GAMEOVA=)
Sounds like a vacuum leak man... check your hoses, check your gaskets.. Intake Manifold etc,...
Old Feb 9, 2004 | 09:52 AM
nice94eg6's Avatar
Default Re: civic revving noises (kKdARIAN)
Well I changed my thermostat and no more noises.
Old Feb 9, 2004 | 10:05 AM
h22avid's Avatar
Sounds to me like the Idle Air Control Valve (IACV). Unplug it and see how it idles. Your IACV is probably located on the rear of your IM/TB area
Old Feb 11, 2004 | 05:21 AM
nice94eg6's Avatar
Default Re: civic revving noises (h22avid)
thanks
Old Feb 11, 2004 | 05:22 AM
BauleyCivic's Avatar
Risky Business
If the bouncy idle only occurs at a cold startup, it is your Fast Idle Throttle Valve...located under your throttle body
Old Feb 11, 2004 | 05:58 AM
nice94eg6's Avatar
Default Re: civic revving noises (BauleyCivic)
did you used to have a d15b7 BauleyCivic? I have a 94 dx but I need more power should I get a swap or just get a z6 head?
Old Feb 11, 2004 | 06:15 AM
JimmyAtlantis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nice94eg6 &raquo;</TD></TR><TR><TD CLASS="quote">did you used to have a d15b7 BauleyCivic? I have a 94 dx but I need more power should I get a swap or just get a z6 head?</TD></TR></TABLE>
Just swap the head Let's start a "Mini-Me Mafia"
Old Feb 11, 2004 | 06:44 AM
nice94eg6's Avatar
Default Re: civic revving noises (JRI94)
how much can I get a head for? will it be comparable to the d15b japan motor? is it easy?
Old Feb 11, 2004 | 06:56 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nice94eg6 &raquo;</TD></TR><TR><TD CLASS="quote">how much can I get a head for? will it be comparable to the d15b japan motor? is it easy?</TD></TR></TABLE>
I picked up a head for $175 shipped. As Bauley puts it, the JDM D15B is a destroked d16z6. It's basically the same thing. Everything you need to know about the Mini-Me swap is here: https://honda-tech.com/zerothread?id=554053 It's time for the newb to start researching I'm also just curious as to what exactly your car is. sedan/hb/coupe?
Old Feb 11, 2004 | 06:58 AM
Risky Business
If I could do it all over again I wouldn't have done the head swap first. Transmission is the most important thing. Do the EX transmission, then a mild cam/ cam gear... and then do bolt ons or a block buildup...
A D15B7 with an EX transmission, P29 pistons, CRX Si Cam, and a good header would RAPE my setup...
Old Feb 11, 2004 | 07:04 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic &raquo;</TD></TR><TR><TD CLASS="quote">A D15B7 with an EX transmission, P29 pistons, CRX Si Cam, and a good header would RAPE my setup...</TD></TR></TABLE>
But Bauley, you already have your head. So say you were to do this ^^^ exact same setup w/ the z6 head (is it possible?), wouldn't that rape the setup that you mention would rape YOUR setup?
Old Feb 11, 2004 | 07:05 AM
Risky Business
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JRI94 &raquo;</TD></TR><TR><TD CLASS="quote">
But Bauley, you already have your head. So say you were to do this ^^^ exact same setup w/ the z6 head (is it possible?), wouldn't that rape the setup that you mention would rape YOUR setup?</TD></TR></TABLE>
No, because P29's in a Z6 is a bad idea...compression is like well over 13:1 AKA not streetable...P29's in a B7 puts the compression right about 12...
Old Feb 11, 2004 | 07:11 AM
But Bauley, you already have your head. So say you were to do this ^^^ exact same setup w/ the z6 head (is it possible?), wouldn't that rape the setup that you mention would rape YOUR setup?</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic &raquo;</TD></TR><TR><TD CLASS="quote">
No, because P29's in a Z6 is a bad idea...compression is like well over 13:1 AKA not streetable...P29's in a B7 puts the compression right about 12...</TD></TR></TABLE>
And there are no other pistons you can use to keep it streetable?
*sigh* I finally found some real good, sane, non-****-talking discussion on H-T
Old Feb 12, 2004 | 08:29 AM
nice94eg6's Avatar
so you are saying I should just get a ex tranny and a cam and it will be faster than it is right now?
Old Feb 12, 2004 | 09:08 AM
The tranny would be a good start. The tranny you (and I) have is ssooooo lllooooonnnnngggg.
Old Feb 12, 2004 | 09:19 AM
nice94eg6's Avatar
yeah I wonder how much it will cost for a tranny and have you ever raced other civics and integras? if so did you win...it was fun
Old Feb 12, 2004 | 09:21 AM
aka010010
Guest
Posts: n/a
probably the idle control valve. mines is broken too
Old Feb 12, 2004 | 09:34 AM
Default Re: (aka010010)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aka010010 &raquo;</TD></TR><TR><TD CLASS="quote">probably the idle control valve. mines is broken too</TD></TR></TABLE>
Nothing like a random post
Old Feb 12, 2004 | 09:54 AM
Risky Business
Really? THATS NUTS!
Old Feb 12, 2004 | 11:39 AM
nice94eg6's Avatar
Default Re: (BauleyCivic)
you guys know how long will I be a trial user? Im sick of not being able to post more than 5 messages...but anyways I'm bored at work...I wish I had the billz to do a swap....
Old Feb 12, 2004 | 12:00 PM
GARBhatch.'s Avatar
Default Re: (nice94eg6)
you'll be a trial user til you stop posting kill stories in your sig.
Old Feb 12, 2004 | 12:03 PM
Jimmy's Avatar
Global Moderator
search ''eratic idle'' and ''idle problems'' recent and archived
Old Feb 12, 2004 | 05:02 PM
h22avid's Avatar
Default Re: (98Hatch00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98Hatch00 &raquo;</TD></TR><TR><TD CLASS="quote">you'll be a trial user til you stop posting kill stories in your sig. </TD></TR></TABLE>
LOL funny stuff man
Seriously though, to answer your question, 20 days... kind of sucks but its the price you pay to be a noob I guess.... I'm in the same boat.
