Ground Wires
Old Feb 6, 2004 | 11:31 AM
JimmyAtlantis's Avatar
Default Ground Wires
Will installing new ground wires accomplish or improve anything? The only reason I'm even thinking about doing this is because the stock wires are still on there, but they're getting a little corroded.
Old Feb 6, 2004 | 11:42 AM
hasback*'s Avatar
F*CK THIEVES!
Default Re: Ground Wires (JRI94)
they help a lil i guess..
Old Feb 6, 2004 | 12:55 PM
Red D Dragon's Avatar
ya if you do it right with nice connections you help a lot.. response, mpg, headlight brightness. Its worth doing.
Old Feb 15, 2004 | 05:00 PM
johnmay19's Avatar
Default Re: Ground Wires (civic_rice)
Yes they will help. I just had a no start , seemed like bad starter. After checking everthing out, I found the ground to trans was bad.
Old Feb 15, 2004 | 05:03 PM
infinatenexus's Avatar
I did mine with 1ga wire and brass lugs. It made a noticeable improvement
Old Feb 15, 2004 | 05:15 PM
TeamNextGenChris's Avatar
they will help if there is currently too much resistance from something being wrong with the current ones.but that wouldn't realy be making new power,just regaining lost power.
chris
enhancedCL9
Feb 10, 2004 10:51 PM
rs
Sep 22, 2003 07:50 PM
THE94GSR
May 28, 2003 08:53 AM
HaUTSaauce
Jan 10, 2002 02:41 PM
