Keeping A/C with B16...got some ????
I searched...didn't find anything...I'm going to be doing a b16 swap...is it possible to NOT disconnect the A/C when pulling the motor? and then install the HASport AC mount when putting it all back together? I mean it's not that big of a deal, if I can just have my system evacuated and pull the compressor, I just might as long as it won't be too big of a deal putting it all back in later. I work at Honda so the evacuation won't be a problem.
From: I told you to wait in the truck in Texas, United States
Yes..
I unbolted it from the a/c bracket and tied it up out of the way
with some mechanics wire..No problem..
Sweet, cuz I'd really like to not have to hassle with evacuating the a/c...although it might be fun to run without my A/C compressor for a couple events and then put it back in when it start to get warm....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88DXCRX »</TD></TR><TR><TD CLASS="quote">Yes..
...No problem..
Same here.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PSUCRX »</TD></TR><TR><TD CLASS="quote">...although it might be fun to run without my A/C compressor for a couple events and then put it back in when it start to get warm....</TD></TR></TABLE>
Just to note that it is much easier to get access to the A/C bracket bolts (and torque them to the proper spec.) with the exhaust manifold removed.
...No problem..
</TD></TR></TABLE>Same here.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by milk »</TD></TR><TR><TD CLASS="quote">
Same here.
Good point...
Same here.
Good point...
I'm also wondering what mount you can use...I know you're supposed to use the HASport one...but for the time being(won't be running a belt on it, just want it mounted) how many bolts line up off the A6 bracket? or is there another US bracket I can use that will mount up perfect?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PSUCRX »</TD></TR><TR><TD CLASS="quote">I'm also wondering what mount you can use...I know you're supposed to use the HASport one...but for the time being(won't be running a belt on it, just want it mounted) how many bolts line up off the A6 bracket? or is there another US bracket I can use that will mount up perfect?</TD></TR></TABLE>
I'm not sure. Mines just sitting on the front crossmember for the time being. So far it's been the perfect place for it.
endless_pain
14
Oct 8, 2022 10:48 AM
forever slow EG6
Jun 12, 2005 03:59 PM
bossman032
Dec 18, 2004 06:55 PM
