Rods for d15's
Old Feb 6, 2004 | 07:18 AM
egizzle8
Guest
Posts: n/a
Default Rods for d15's
I've got a d15b2 (ef dx) block laying in my garage that's got 80k on it and was thinking building a minime with it. Question is what rods are available for the d15 or any stock rods that would fit it like the ls rods or anything?
Old Feb 6, 2004 | 07:49 AM
egizzle8
Guest
Posts: n/a
Default Re: Rods for d15's (egizzle6)
anyone? would the ls fit?
Old Feb 6, 2004 | 08:28 AM
lohatch's Avatar
no the ls rods will only work with the D15 because the cranks are different. basically the only thing available are a few aftermarket ones and the stock ones. stock rods should be fine if you are just planning to up your compression with the mini-me. but if you are going to spray on it or boost it for some reason you might experience some broken rods i personally have have pretty good luck with stock d15b7 rods up to 10 psi but thats the risk i take
Modified by lohatch at 5:10 PM 2/20/2004
Deco989
27
Jan 13, 2011 05:24 PM
RACEPAK
Jul 14, 2007 06:49 PM
Weston
Oct 15, 2006 09:17 AM
vtec_yosh
16
Jun 25, 2004 10:59 PM
S9i1R
Mar 23, 2004 09:01 PM
