Removing ABS in my 94 hatch
First off I did search, but everything was for an integra.. I don't have an integra..
I bought my SI for all the nice features you get with one. well, now I have already removed power steering, and AC, so why not take out the ABS unit(yah, I paid more money for a sunroof
). This is not my only car, and I try not to drive it at all in bad weather. I am very used to driving with NO ABS, so I don't want to hear it isn't safe. Basically from what I've read with the integra, you need the Prop. valve, master cylinder, brake booster, and the NON-abs lines. Is it basically the same for my 94 civic? I am guessing I can use those from any vx/cx/dx(not sure which may have come with abs if any of those).
I am building an engine now, so I will have the engine out of the car when I do this, so that should make my life easier.
I really appreciate any insight you guys might have.. thanks a bunch!
). This is not my only car, and I try not to drive it at all in bad weather. I am very used to driving with NO ABS, so I don't want to hear it isn't safe. Basically from what I've read with the integra, you need the Prop. valve, master cylinder, brake booster, and the NON-abs lines. Is it basically the same for my 94 civic? I am guessing I can use those from any vx/cx/dx(not sure which may have come with abs if any of those). I am building an engine now, so I will have the engine out of the car when I do this, so that should make my life easier.
You may need new axles too. But ABS axles may work they'd just have the ABS rings on them that would be unused, or if u dont need them then pop them off.
Munkyw3rkz.webs.com
i swapped in a 4X114 ITR set up on a 95 Civic EX with ABS.....disconnected the ABS and got rid og the lines.....
everything the same...no lights everything all good!!!
Mike457
Apr 25, 2018 12:39 AM
rex_racer728
Sep 2, 2006 09:26 PM
