Camber Help
Old Feb 6, 2004 | 02:33 AM
JMod's Avatar
Default Camber Help
I got a question for you guys, I have my Sol lowered on Neuspeed Race springs w/ stock shocks, the drop is 2.25" front & 2.0" Rear. I'm getting alot of tire wear on the inside of my tires, the outside seems to be brand new. I really don't know a whole lot in terms of the camber/toe adjustments. Heres a few pics, lemme know what you guys think needs to be done, camber kit or alignment, or both. Thanks.
Old Feb 6, 2004 | 02:41 AM
boostedx's Avatar
Default Re: Camber Help (BucsJosh)
hell yeah man....you need a camber kit and after you install it have an alignment shop set it up all nice....they can adjust alignment, camper, toe, caster....blah blah but u definately need a camber kit. also neuspeed race with stock shocks is not good at all...invest in some shocks
Old Feb 6, 2004 | 05:35 AM
itsJDMyo's Avatar
Default Re: Camber Help (boostedx)
yup, you need a camber kit, my tires look exactly like that right now...i just got my camber kit earlier this week, and will be installing it hopefully today
Old Feb 6, 2004 | 06:06 AM
scratchy's Avatar
camber is the hondas worst enemy so find a good camber kit and install the ******* thing, best out is a company called spc
Old Feb 6, 2004 | 07:34 AM
JMod's Avatar
Default Re: Camber Help (scratchy)
Which camber kit would you guys recommend? I've heard of the Skunk 2 and the Ingalls, either of those better than the other?
Old Feb 6, 2004 | 12:11 PM
JMod's Avatar
bump
Old Feb 6, 2004 | 12:22 PM
=GAME='s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scratchy &raquo;</TD></TR><TR><TD CLASS="quote">camber is the hondas worst enemy </TD></TR></TABLE>
negative. bad toe cause more wear than camber.
btw ive been running the ingalls kit on my 93 hatch for over 2 years. its been doing great except for after a couple months the bushing starts to squeak. i just spray wd40 on it until it squeaks again.
Old Feb 6, 2004 | 12:47 PM
chads's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedx &raquo;</TD></TR><TR><TD CLASS="quote">hell yeah man....you need a camber kit and after you install it have an alignment shop set it up all nice....they can adjust alignment, camper, toe, caster....blah blah but u definately need a camber kit. also neuspeed race with stock shocks is not good at all...invest in some shocks </TD></TR></TABLE>
your wrong they cant do anything about camber thats why people buy camber kits.
but they can fix your "toe in" problem, wich will fix your tire wear problem. i dont think your camber is bad enough to need a camber kit.
Old Feb 6, 2004 | 01:00 PM
ProEater's Avatar
Default Re: Camber Help (chad's)
if you can afford one go for it, but i dont think you are in immediate need of a camber kit
ingalls and skunk2=
Old Feb 6, 2004 | 01:56 PM
Mugen Hamster's Avatar
Default Re: Camber Help (ProEater)
SPC upper control arms with built in balljoints are better than both ingalls and skunk. I've never read about anyone's SPC balljoints failing, unlike skunk2. Oh, and as for the ingalls, you have to repress your existing balljoints into their arms.
Old Feb 6, 2004 | 02:08 PM
lonefuzzy79's Avatar
Default Re: Camber Help (AntiRice Superstar)
Your toe is what is killing your tires. With a good drop you might get -1.5 degress or so wich is a good thing. Bad toe will eat tires with the quickness. if you are running much more tha -2.0 you might consider a camber kit but really you are not so extreme that it is going to be that bad, toe is the killer, remember that. And yeah, a $60 alingment will fix you right up.
Old Feb 6, 2004 | 02:14 PM
Nader_D's Avatar
Default Re: Camber Help (lonefuzzy79)
when i got my springs installed (skunk2 race springs) the mechanic that did it for me, knew this washer trick, cause there is little if any camber problems with my car and my current tires...maybe if put some rims on it i could tell better, but i dunno thats what i was told
Old Feb 6, 2004 | 02:28 PM
Nocturnal's Avatar
Default Re: Camber Help (Nader_D)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nader_D &raquo;</TD></TR><TR><TD CLASS="quote">when i got my springs installed (skunk2 race springs) the mechanic that did it for me, knew this washer trick, cause there is little if any camber problems with my car and my current tires...maybe if put some rims on it i could tell better, but i dunno thats what i was told
You can only use washers for the rear camber. The front you need an actual camber kit.
Old Feb 6, 2004 | 02:56 PM
Targa250R's Avatar
be professional
Go to an alignment shop and ask for the print-out to see what your numbers are actually like. If you have less than -2.0 degrees of camber, then I wouldn't even bother with a kit; just have them center your toe.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scratchy &raquo;</TD></TR><TR><TD CLASS="quote">camber is the hondas worst enemy</TD></TR></TABLE>
Negative camber is my Honda's best friend. 0 degrees handles like ****.
Old Feb 16, 2004 | 08:43 PM
95excoupe's Avatar
Default Re: Camber Help (Knocturnal)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Knocturnal &raquo;</TD></TR><TR><TD CLASS="quote">
You can only use washers for the rear camber. The front you need an actual camber kit.</TD></TR></TABLE>
What??
here buy my kit way cheaper than new its in my sig..
donger
Jan 30, 2006 01:10 PM
sohcvtec97
Nov 2, 2005 08:44 AM
Quiks66
Sep 26, 2004 01:11 PM
GUNNER666
Jul 28, 2004 08:26 AM
crookedletterd
Aug 2, 2001 12:11 PM
