Is it hard to change the Clutch/Brake levers ??
Old Feb 6, 2004 | 01:06 AM
etmoron's Avatar
Default Is it hard to change the Clutch/Brake levers ??
well i dropped my bike * o wells * and the clutch lever is bent out of shape and all of that . so is it hard to change the levers or its as simple as a bycicle lever ??
o yeah
2003 yamha r6 if anyone wants to know
Old Feb 6, 2004 | 07:04 AM
tonydatyga's Avatar
Default Re: Is it hard to change the Clutch/Brake levers ?? (etmoron)
very simple, just know how to adjust the clutch free play
Old Feb 6, 2004 | 03:25 PM
etmoron's Avatar
Default Re: Is it hard to change the Clutch/Brake levers ?? (tonydatyga)
how much free play would be needed ??
Old Feb 6, 2004 | 03:51 PM
Thasty's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tonydatyga &raquo;</TD></TR><TR><TD CLASS="quote">very simple, just know how to adjust the clutch free play</TD></TR></TABLE>
I dropped my CBR in the garage and bent the handle back to normal with the closed end of a wrench. IF you dont want to do that, just unscrew it and put the other one in, I never even played with the adjustments it stayed the same.
Old Feb 13, 2004 | 02:23 PM
90Ninja
Guest
Posts: n/a
Default Re: Is it hard to change the Clutch/Brake levers ?? (OnlyNod)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OnlyNod &raquo;</TD></TR><TR><TD CLASS="quote">
I dropped my CBR in the garage and bent the handle back to normal with the closed end of a wrench. IF you dont want to do that, just unscrew it and put the other one in, I never even played with the adjustments it stayed the same.</TD></TR></TABLE>
Sometimes if you try to bend them back they will snap off. Very easy to change. Look for aftermarket because the oem's are very expensive.
STEVE-O7
Oct 10, 2007 05:18 PM
ic89
Oct 17, 2006 11:59 AM
iLude
Honda Motorcycles
Aug 31, 2006 01:02 PM
one slow coupe
19
Jan 10, 2005 08:46 PM
AspectIndustries
Jan 5, 2004 07:49 AM
