Can't remove crankshaft pulley - PLEASE HELP!!!
Old Feb 5, 2004 | 11:27 PM
s1lv1a9999's Avatar
Default Can't remove crankshaft pulley - PLEASE HELP!!!
My gf has a Honda Civic 94 GLi auto, the water pump needs replacing which means removal of the timing belt. Problem is, the nut on the crankshaft holding the pulley on is the tighest nut i have ever seen! i tried how i normally do it with other cars - turning over the motor with a breaker bar on the nut. didn't budge after like 10 tries. i heard u can take the dust cover off and wedge the flywheel with a screwdriver and use a knuckle bar to break it, but it is auto and the flex plate i fear would not be strong enough to hold, i can't find the dust cover on the auto anyways. HOW do i get it off...?
cheers, Mark.
cebonus@hotmail.com
Old Feb 6, 2004 | 12:39 AM
Evs-One's Avatar
Solbros Owns Me
Default Re: Can't remove crankshaft pulley - PLEASE HELP!!! (s1lv1a9999)
drive to you local heavy duty machine repair shop and have them hit it with an impact real quick.
I would also be weary about the flex plate.....BUT, if you think about it, the outer diameter of the plate reduces the torque applied to it tremendously. Just a thought though.
Some people put it in gear and stomp on the brakes....but this is too much stress on drivetrain for my liking
Old Feb 6, 2004 | 04:44 AM
Tony Starks's Avatar
Default Re: Can't remove crankshaft pulley - PLEASE HELP!!! (Emerika)
Impact gun. Nothing else.
Old Feb 6, 2004 | 04:48 AM
kKdARIAN's Avatar
Vice President/CEO
Default Re: Can't remove crankshaft pulley - PLEASE HELP!!! (Tony Starks)
just like everyone else said.. an impact wrench is how your gonna get it off..
i had this problem when i busted my timing belt.
ugh
Old Feb 6, 2004 | 05:11 AM
99blackcivicSi's Avatar
Default Re: Can't remove crankshaft pulley - PLEASE HELP!!! (kKdARIAN)
i have had some that i could not get off with an impact. So i had someone lock the flywheel while i got on it with a 3 foot breaker bar and a jack handle for an extension that works wonders
Old Feb 6, 2004 | 05:24 AM
93CivicSI's Avatar
600 ft lb impact wrench..
Old Feb 6, 2004 | 05:34 AM
T.J.'s Avatar
Default Re: Can't remove crankshaft pulley - PLEASE HELP!!! (99blackcivicSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99blackcivicSi &raquo;</TD></TR><TR><TD CLASS="quote">i have had some that i could not get off with an impact. So i had someone lock the flywheel while i got on it with a 3 foot breaker bar and a jack handle for an extension that works wonders</TD></TR></TABLE>
Its how ive always done mine
Old Feb 6, 2004 | 05:59 AM
Dan GSR's Avatar
Default Re: Can't remove crankshaft pulley - PLEASE HELP!!! (Skunk2whore)
i don't have any air tools
and have yet to meet a crank pulley that won't come off with the right tools
all i have is the crank pulley holder and some large breaker bars
Old Feb 6, 2004 | 07:13 AM
yellow_jacket's Avatar
Default Re: Can't remove crankshaft pulley - PLEASE HELP!!! (Dan GSR)
You can try wedging a breaker bar against the floor, and bumping the starter.
Dutch_commando
11
Jun 24, 2017 08:26 AM
BrutalBrandon
Nov 12, 2007 05:17 AM
eg_h22
Oct 15, 2007 04:14 PM
mike
Mar 9, 2002 06:32 PM
94civicx
11
Jan 15, 2002 10:56 AM
