moroso pan, b16 rods, apexi header, crank pulley w.o p/s or a/c
R.I.P. Andy
B Series Moroso Oil pan with sump 10k on it - $250
Stock B16 Con Rods - $75 shipped
Apexi USDM Header w/EGT bung perfect shape - make offer
crank pulley with p/s and a/c removed - $50 shipped
Sohc Shift Linkage - worth anything to anyone? make an offer
R.I.P. Andy
I have no where to host pics, give me your email adress and I would be glad to send you some pics! and to answer your questions yes it will fit a type r and yes there is a return line fitting and a oil temp sensor fitting. its a 5 qt. baffled pan
R.I.P. Andy
email me if you want also, I check email alot more often then honda-tech... allmotoreg6@aol.com
R.I.P. Andy
http://www.inlinefour.com/apgtexman.html everything you need to know about it here, besides the fact it has a egt bung already welded into the header...or a pic is here, mine is flawless, so its no different then this pic.
Mr. Softee
Mar 1, 2004 10:27 AM
