OBD2 code p1337??????
Old Feb 5, 2004 | 07:01 PM
teg_b18c1's Avatar
Default OBD2 code p1337??????
I drive a 96 teg gsr I got a check engine light the other day so I scaned the ecu with a scan tool and got P1337 & P1336. I looked them up and they both mean the same thing one is (no signal) the other (intermitent signal) (Crankshaft Speed flucaution). I was told it was a VSS. I replaced the VSS and it did not fix the problem. If I clear the code the CEL comes rightback on as soon as I start the car.
Could someone please tell me which sensor is bad?
Old Feb 5, 2004 | 07:35 PM
clockworks's Avatar
Default Re: OBD2 code p1337?????? (teg_b18c1)
check the circuit between the crank sensor and the ecu, wiggle connectors while watching an ohmeter for continuity. If it comes on right away, there is probably an open or short somewhere. if it takes a few trips, then it is intermittant; the ECU uses two trip detection logic in this case.
Old Feb 6, 2004 | 04:21 AM
EE_Chris's Avatar
The code is for the CKF sensor down by the oil pump.
Where did you get the idea that it was the VSS?
Old Feb 6, 2004 | 01:22 PM
teg_b18c1's Avatar
Default Re: OBD2 code p1337?????? (EE_Chris)
My local acura dealer told me thats what it was.
gsr dood
Jan 5, 2008 04:10 PM
cheeks97R
Apr 17, 2005 09:34 AM
highboostb18c1
Mar 28, 2005 09:06 AM
teg_b18c1
Feb 5, 2004 07:06 PM
RRRex
May 7, 2003 05:06 PM
